I called earlier, but was not able to stay on line long enough to complete the session. I had been trying to use my Image Zone software (part of the package I installed along with HP Photosmart Printer 8250) but could not open it because I kept getting an error message telling me that I needed to use a disk. The technician I was talking to suggested uninstalling one of the HP programs (I forget which) from my Control Panel, but I didn't complete the operation. I now need to know which of the programs I should uninstall, and exactly what procedure to follow afterwards. The programs are: Extended Capabilities 5.3... Image zone 5.3 ... Imaging Device Functions ... Photosmart 330series etc ... Solution Center and Imaging Support Tools 5.3 ... Update ... HPSU306Stub ... Mike England
  • 9 more comments
  • t1gger Apr 25, 2008
    I nearly did that earlier, but decided not to in view of the risks involved in that. The technician obviously thought that a partial uninstall would be the wise option, so that's why I just need to know which of the HP programs I need to remove and then retrieve from the disk.
  • t1gger Apr 26, 2008
    Have a bit of time now, if you do. In answer to your earlier question about whether the programs (listed above)are all part of the HP 8250 printer program - I have to assume they are, because the printer is the only HP device I'm using , and was installed with the disk.
    I assume the programs I listed all originated from the insatllation disk, since the printer is the only HP device I have installed.
    Do you have a solution for this problem?
    I want to access my HP Image Zone program. When I click on the desktop icon I receive a Windows Installer message telling me: "The feature you are trying to use is on a CD-Rom or other removable disk that is not available." I have the disk I used to install my printer (Photosmart 8250) but need to know how to go about uninstalling the 7 HP components from my Control Panel. Maybe I don't need to remove them all. Warnings I'm getting about the serious consequences of uninstalling these components leave me in a quandry. The components are: Extended Capabilities 5.3 ... Imaging Device Functions 5.3 ...Image Zone 5.3 ... Photosmart 330 etc. series ... Solution Center and Support Tools 5.3 ...Update ...HPSU306Stub ... Any advice?
  • t1gger Apr 27, 2008
    I'm using XP.
    I received an email notifying me that you had replied to my message about having XP, but it's not showing up here. I should be able to click on a couple of links in the message, but neither of them responds.
    Bingo. Thanks ID. I've run out of time on this tonight, but I'll give it a whirl in the morning. Thanks for taking the time to give such clear, concise directions. Will get back to you on this.
    Mike
    I downloaded to my desktop the edu_cdrom_A_nonetwork.exe file from the site, but the instructions I received in the installation procedures refer to working with an actual CD ROM disk. The file I downloaded comes without instructions. All you can do is 'run'it. Before that can happen, I assume I would need to uninstall the old programs and perform a few other steps. What now?
    Mike
    Hi ID,
    I had already done that by the time I got this message. Everything's fine now. Many thanks. How's the rating done?
    Mike
    Hi ID,
    This really is a difficult site to work in. I looked for the rating symbols at the bottom of your solution but found none. I tried using the ones to the right of your name at the top, but got no response from that. So I clicked on your icon and went to your profile where I found rating symbols and selected the FixYa group. Now I'm seeing that rating appearing for myself next to my own name, as if I rated myself. I'm still scratching my head over that one. If it's possible to rectify, I'll gladly do it.
    Mike
    President:
  • 2,712 Answers
Hello Mike,
Couple of possible steps to do:
1. Some applications require that the CD be IN the CD Drive to function ( like in some games). Is the HP CD in the CD Drive when you double click the desktop icon? This could be one of the reasons you are getting this message. So try putting the CD in the player and then launch the application if you havent done so.
2. If it is still giving you the error, it could be that the software on the disk is corrupt. In this case, click HERE to download the software directly from the HP website. Mind you, the Vista edition is almost 68Mb, so it could take a while. Once done, unistall all HP entries through the Add/Remove Programs. Since you say that this is the only HP product you have, there shouldn't be a cause for worry. You can always reinstall them. DO NOT INSTALL THE SOFTWARE YET!
3. Once downloaded, do a clean boot/installation as outlined below. Booting clean is a way to eliminate programs from conflicting with installation of software.
To Boot Clean in Windows Vista:
Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Maintenance
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options:
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
After restarting, install the downloaded software. Next , do the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
If you are using a different OS, please post back and I will send you the appropriate steps for that OS. Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
  • 7 more comments
  • Swilin Sampson
    Swilin Sampson Apr 27, 2008
    OK, download the latest software
    for Windows XP from HERE.
    To Boot Clean in Windows XP
    1. Click Start --> Run --> Type MSCONFIG --> Click
    OK
    2. On the General tab, choose Selective Startup
    3. Uncheck Process SYSTEM.INI file
    4. Uncheck Process WIN.INI file
    5. Uncheck Load Startup Items
    6. Click on the Services tab
    7. At the bottom, check Hide All Microsoft Services
    8. Uncheck all boxes in the window or click the button
    labeled Disable All
    6. Click OK
    7. Click Restart
    After restarting, install the downloaded software. HERE
    is a link on the HP website giving step by step installation procedures.
    Next , do the
    following:
    1. Click Start --> Run --> Type MSCONFIG-->
    Click OK
    2. Replace checkmarks in the
    items that you previously removed them from.
    3. On the General tab,
    4. Click OK
    5. Click
    YES, when asked to restart your computer
  • Swilin Sampson
    Cheers mate!
    And dont forget your pint of Guiness before you hit the sack =p)
    By the way, if you're having trouble with the links, let me know which links, and I will just type the URL here without hyperlinking them.
  • Swilin Sampson
    Yes, first uninstall the older software and then follow the clean boot procedures for XP that I outlined above..
  • Swilin Sampson
    Glad that worked out. Well , to do a rating, at the bottom of my post you will see 4 options - inappropriate, thanks for trying, helpful and Fixya. Just select the Fixya option, as your problem has been resolved :)
    And thanks for the rating in advance!
    Cheers!
    IrishDruid
  • Swilin Sampson
    You will see this below each expert's solution..make sure you select the rating below MY post or it may be credited to someone else ;)
  • Swilin Sampson
    Hi Mike,
    You still haven't rated the solution...
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    @ IB4G2008:
    Thanks, mate. I always try to see the issue through to a resolution if I can, or until the user gets fed up and doesnt respond, LOL.
  • Swilin Sampson
    Hi Mike,
    I believe these days there is only an "accept" and "ask" button for premium solutions. Well, just go ahead and click on the "accept" button below my solution.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Thanks mate, for the rating. BTW, the printer is a good choice. Its one of the best in the market for home photo printing. Enjoy!
    IrishDruid
    Brigadier General:
  • 3,614 Answers
Use your printer installer, there you can see an options if you want to remove it or repair it...
    Genius:
  • 3,587 Answers
Sounds compelling...did you have a chat going?
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Apr 26, 2008
    perhaps..I know much about HP..but your issue seems a little convoluted..what precisely is the issue here?
  • Patrick Michaels
    it's really simpler than that..
    remove the old software
    go to the main site, get updated version
    tune up your computer
    get back in the game..
    and don't mess around with trying a custom install
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    well..this one is really dragging on a bit, isn't it?
  • Patrick Michaels
    high fives Irish Druid, for sticking through one of the longest sessions on Fixya platform..
  • Patrick Michaels
    You'll get a note on email in a few days..Make sure you give Irish Druid the Fixya(since this problem would have been solved if you took any of the other experts advice..except mine) earlier.
    Genius:
  • 3,422 Answers
Would you like a remote assistance to uninstall it completely.
Waiting for your reply
Posted on Apr 25, 2008
  • 2 more comments
  • Priya darshan Apr 26, 2008
    Hi again,
    Why don't you remove all of them and install them back again.It is always better to do that.
    And don't worry we are not here to steal any data from you.Just to make it easier and faster for you i provided you with that option anyways it's your wish.
    One more question the programs which you gave are all these part of the printer software.
    This program has to be removed fro sure Photosmart 330series etc ... Solution Center and Imaging Support Tools 5.3.
  • Priya darshan Apr 27, 2008
    i already told you we could have a remote assistance to fix this up.I would have solved your problem in 10min.Anyways its your wish....
Unable to install hp Image Zone & iris on Windows Vista. Help...
HP Image Zone is no longer designed by HP for Vista PC's
There is another software available Called HP Photosmart Essential. Download the Software from this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414784&lc=en&dlc=en&cc=us&product=3857372
HP Photosmart Essential is also called as HP Photo Creations
Jun 22, 2010 | HP Scanjet 3770 Flatbed Scanner
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Dec 02, 2008 | NorStar M7310 Corded Phone
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Can't see anything on CD after burning image file
Make sure the size of the .img file is comparable to the total size of the files you want to burn. if the sizes are similar, then you may have an open session on the disk. many optical drives wont read the information in an open session. check your burn options and select 'close session', then reburn. If the size is very small, then the .img file may not have been created properly.
Nov 24, 2008 | Adobe Photoshop 7.0 for PC
Erro occurred
If you can't open the toolbox there is a software issue. A complete uninstall and reinstall might be the solution. (Disconnect USB cable if connected with usb cable), Perform an uninstall from the software, when ready, open add/remove programs in the control panel, uninstall image zone, extended capabillitys, and HP update, restart pc search the CD for scrubber.exe and doubble click on the file. Reinstall the full software.
Aug 04, 2008 | HP LaserJet 2840 Printer
Unable to Access HP Image Zone
this worked for me .... open msconfig hit startup tab and scroll to HP Image Zone fast start, and disable , apply close and restart computer
Jun 14, 2008 | HP PSC 2355 All-In-One InkJet Printer
Accessing Image Zone software
Went to the HP site, downloaded the printer program, removed the old program and installed the new one..
Apr 26, 2008 | Office Equipment & Supplies
Using hpscanjet4070 photosmart on a Dell with MSWinXP sp2
chances are you had a previous hp printer installed on the computer. image zone is an older version of software for hp printers. look for photosmart essentials for editing photos
Feb 25, 2008 | HP Scanjet 4070 Flatbed Scanner
Image zone plus
tell me camera model & if it having memory stick or not if ur havinf it then u can transfer it from memory stick also
Oct 15, 2007 | Microsoft Windows XP Home Edition
78 people viewed this question
k24674
jasbo
jasbo
