Question about Kyocera FS-2000D Laser Printer
Mi impresora Kyocera Ecosys fs-c5030n presenta un error en el cual el pamel muestra el mensaje "call service f000" al encenderla.
  • 25 Answers
SOURCE: problem with EcoSys Kyocera FS2000D
that is a fuser code check the fuse
Posted on Dec 31, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
don_farr
  • 1018 Answers
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Posted on Nov 19, 2009
anantakumarj
  • 330 Answers
SOURCE: black page printing
please open drum unit and there you can find a unit called charge unit inside this one thine wire is coming clean that wire and check ...... if you want full details please chat with me ... my ID anantakumarjena0@gmail.com
Posted on Jan 12, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: cuando instale a 5to usuario
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
My canon imageclass mf4770n keep saying download waiting when i push the start button why
Voy a describir el procedimiento tal y como lo hice y logre revivir mi impresora.
1. Utilic? un equipo en el que jam?s fue instalada la impresora as? no instalar?a el driver autom?ticamente. (No s? si funcionar?a desinstalando el driver de la propia PC)
2. Conectar la impresora al equipo y esperar a que muestre el mensaje USB AVAILABLE. (IMPORTANTE. no instalen el driver de la impresora. Windows la reconocer? mas dar? error al no encontrar un driver compatible)
3. Descargar la utilidad de actualizaci?n de canon Win_MF4800_4700_FirmUpdateTool_V1504_usEN.exe
4. Ejecutar la actualizaci?n de Canon. Esta actualizaci?n deber? detectar el firmware da?ado y proceder? a actualizarlo. En mi caso fue el N?mero 4.
NOTA: es importante disponer de una fuente de respaldo (UPS) ante probabilidad de fallo en el suministro de electricidad ya que ante un fallo como este quedar?a la impresora inservible.
Sep 27, 2014 | Canon imageCLASS MF4770n Black/White Laser...
TENGO UNA IMPRESORA HP LASERT JET Y ME MUESTRA SOLO UN MENSAJE QUE HAT UN ERROR 53 , 05 Y ME INDICA APAGUE Y ENCIENDA PERO SE REPITE TODO
No puedo encontrar error 53 en el manual de servicio... puedes revisar el codigo de error y volver a publicarlo?
Mar 31, 2014 | HP LaserJet M1120 MFP All-In-One Printer
Si levanto la pantalla de mi notebook no muestra nada, al bajarlo ante de cerrarlo muestra bien el contenido. mi notebook es compaq prsario c700.
Llevelo a servicio autorizado HP porque lo que presenta es problemas con el Flex (cable plano) que lleva la señal desde la placa madre debajo del teclado hacia el monitor LCD en la parte superior, Mientras, tal vez pueda conectar un monitor externo al laptop por el momento. pero es un error serio que debe ser atendido por personal calificado por HP
Mar 12, 2011 | Compaq Presario C700T Notebook
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Kyocera FS-2000D Laser Printer Logo
138 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
