Question about Goldstar DH304 Dehumidifier
The dehumidifier is plugged in and turned on, but isn't running.
  • Goldstar Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Just bought a dehumidifier in the ground level of a high ranch I am very frustrated because I dump the water every day I waas told to keep the humidity at 45- 50 but it keeps on going up This seems to be a...
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Sep 17, 2011 | Friedrich Dehumidifiers
The dehumidifier motor is on but only extracts tablespoonfuls of moisture from the air every 48 hours. In other words it isn't functioning as it should. Model #DH40; traceability code GR and barcode...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 10, 2011 | Goldstar DH304 Dehumidifier
We just bought the DE45EJ. We removed it from the box and plugged it in....nothing. No lights, no beeps, no hint of life. The power source is good. The room temperature is normal. The bucket isn't full...
If you just purchased and it won't turn ON, don't waste time trying to fix the unit. Return it to the place of purchase for a replacement unit or a refund.
Thanks for choosing FixYa.
Sep 10, 2011 | Haier 45-Pint Dehumidifier
Our LG LHD45EL 45-pint Dehumidifier is not collecting water. The fan is running, and there isn't any error message in the display. I have tried unplugging it for a while to see if it would re-set....
heatman101
Jul 14, 2011 | LG LHD45EL Dehumidifier
I have the a Kenmore dehumidifier sometimes it runs fine and other times just the fan runs not the compressor or just the opposite the compressor runs not the fan it is only 2 1/2 years old. What should...
Kathy, I'm not sure you have a problem with the dehumidifier. Depending on which mode you're operating it in, the fan will run in an effort to recirculate the air. If the humidity level rises above the level you have the unit set on, the compressor will then turn ON. This is particularly true, if the unit is operating in continual mode. Then there are other times the fan isn't active, but the compressor turns on when the humidity sensor feels a rise in humidity. So, for the most part, I don't think it's a problem.
Just be sure that you clean the air intake filter at least once every two weeks, during times of daily operation.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Kenmore 54351 Dehumidifier
Dehumidifier isn't not removing humidity. Fan and lights are working, but the water container remains empty. It is not pulling water from air. I think that the heating element may not be working.
heatman101
May 25, 2011 | DeLonghi DE500P Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
When plug the dehumidifier in, it trip my gfi. If I plug it into a standard outlet, it won't turn on.
Hi, It would seem as though the compressor is bad...
heatman101
Mar 01, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifier is not turning on (and, yes, it is plugged in).
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 03, 2010 | Goldstar DH304 Dehumidifier
Goldstar DH304 Dehumidifier Logo
62 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
