Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
  • 15,935 Answers
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Whirlpool duet washer will not drain or spin, keeps making a rumbling noise, what can I do?
Hello Randall;
My name is Peter. I am a retired field service appliance technician.
I have a Whirlpool Duet clothes washer. They are nice units. The information following is based on my model number GHW9150PW0.
You do not have a drain problem. I am more concerned with the rumbling noise.
1.) On both the front and back end of your drum you have a spring loaded counterweight. It is possible you have a broken spring.
Part #: 8181762 Cost: $24.00
Part #: 8181645 Cost: $17.00
Your should also check out your drive belt. At a high speed it may be slipping.
25395045-azn3vdefrt5enyqdbzatir1e-2-9.jpg Part #: 8181670 Cost: $25.00
The above will effect your independent motor control located inside the washer, located inside your unit.
Feb 01, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
I need a user manual for my Whirlpool Duet Steam Washer, Model # WFW 9500 TW 01.
You can go to www.whirlpool.com and select Owners Center, then select Manuals and Literature. Put in the model no. and you should find one there. Click HERE for this manual.
Hope this is what you need, Please rate and comment Thank You Joe
Sep 07, 2011 | Whirlpool Washing Machines
Noise when the drum turns.
Hello, I have the same issue with a machine now 5.5 years old. At lower drum rotating speeds, a loud clicking (almost stripping sound) is heard. I have only inspected from the lower front cover and found nothing. Will also look in the back for clues...
Dec 30, 2009 | Whirlpool Washing Machines
How to replace the door bellows seal ?
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
343 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
