Question about Car Audio & Video
How do I get the cradle out of the car? - Car Audio & Video
    Genius:
  • 1,478 Answers
Please i will like to know if it is the speaker or the radio you are trying to get out of the car.
Knowing this will help give accurate information on how to go about it. I await your comment to this.
Take care.
Posted on Aug 03, 2010
  • r_dillard1 Aug 03, 2010
    I am tryig to remove a cell phone cradle Kim KRZR
Does the Hyundai accent 2000 have a front cradle?
if it is a unibody then it will have an engine cradle or sub-frame that supports the engine and transmission. If you plan on replacing the subframe you will need to support the engine and transmission from the top side with an engine support fixture.
Subframe/cradle
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 07, 2016 | 2000 Hyundai Accent
I need to Remove and replace the harmonic balancer on my 5.3...everyone talks about lowering the cradle but no instructions on how to do this
Jack the passenger side up on the cradle. Use a jack stand or blocks for safety, behind the cradle. Remove the tire. remove the dust shield. To lower the cradle there are two bolts to release, front and back. You might have to remove the cover under the bumper to get to the front one. remove those bolts and lower down the cradle. You might have to pry down on the cradle and use a block to hold it down to get the balancer out.
May 29, 2016 | 2007 Pontiac Grand Prix GXP Sedan
Have NOKIA CK-7W and phone works fine through in car speaker on bluetooth when not in cradle but it disconnects bluetooth when in cradle and doesnt go through car speakers - help!
you will need to clean the pins on the botton of the cradle and phone, use a dry toothbrush, these cradles were commonly intermittent due to poor design. check the pins to see if any are bent and check the connector at the bottom of the cradle.
Dan
Feb 20, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
How do I take out the spare tire from under the ford explorer?
hi from uk if the spare tyre is fitted/secured under the rear end of car on a cradle?? then to remove it open rear hatch lift carpet up near to the rear cross member that hatch closes onto you should see a bolt head in a dished hole ? this bolt head is same size as wheel nut brace of your car so using the wheel brace turn the bolt anticlockwise as you would to unlock wheel nuts? you will have to turn for a while as this bolt is hooked to the tyre cradle you will see tyre lower as you turn when lowered fully to its stup ? you then lift cradle+tyre up enough to unhook bolt hook from cradle to reinstall is reverse operation to above till bolt tightens with tyre loaded WARNING! do not drive vehicle without a tyre loaded on cradle and secured as to simply rehook and secure bolt is not sufficient and the cradle WILL jump off when on rough road as well as an annoying rattle from loose cradle hope this helps
Dec 27, 2009 | 1998 Ford Explorer
What is a engine cradle
The engine cradle holds or "cradles" the motor in place. It acts as the sub frame of the car. Hyundai has a big problem with the cradles rusting through in places making the car unsafe to drive.
Oct 12, 2009 | 2001 Hyundai Sonata
Strut-to-cradle bushing on a 1999 Saturn
Loosen all the cradle bolts,But do not take them out.Place good floor jack under cradle,and remove one bolt at a time,but keep them ll loose to be able to relieve pressur on the bushings.I hope this is helpful.
Oct 06, 2009 | 1999 Saturn SL
Unit will not turn on
Check for voltage at the end that plugs into the cradle. If no voltage there, check glass fuse inside end that plugs into car plug. If there is voltage at the cradle end and it still doesn't turn on then it's the cradle. The cradle fails over a short time inside the cradle plug. You can hard solder the cable end to the cradle circuit board, which is a delicate procedure which I have perfected but I am an electronics person. If you want to buy a new cradle it will fix your problem for turning on the gps but I recomend a cable tie on the cradle cable end to stop the strain on the connector so the new cradle connector will last a long time.
Jan 24, 2009 | Magellan RoadMate 700 GPS Receiver
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
In car phone
The cradle is placed that the phone is without comprehension
That is the problem, replace the cradle to someplace else.
Jun 30, 2008 | 2004 Mercedes-Benz C-Class
No Voice
Have you tried someone elses car cradle? There is a small amp in the car cradle which is probably fried, Is it under warranty? If so ship it back, if not, find another zumo user to test if it's the cradle or not, then still try Garmin, if the response is 'no warranty', shop for a cradle on ebay..seen them NEW for less than $ 50
Jan 02, 2008 | Garmin zumo 550 GPS Receiver
Car Audio & Video Logo
11 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
