Question about Cameras
Everytime i turn my camera on it says lens error. i already charged the battery, and turned it off and back on and it is still doing it
  • 1,557 Answers
Lens error means the lens is failing to come out this is due to damage to the cogs in most cases its because the unit was bumped hard or dropped the repair cost for this fault is around $ 250 so in most cases its far cheaper to have the unit replaced.
best of luck ..
Posted on Aug 03, 2010
SOURCE: camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Posted on Feb 18, 2008
jerryg50
  • 1689 Answers
SOURCE: my digital camera say lens error:21
The lens has a servo fault. This can be either the lens motor, the helicoil in the lens is jamming, or the servo drive electronics has a fault.
You will have to send the camera for service if you want to fix this. I doubt you can fix this yourself unless you have access to the parts, and have the training and tools to do this type of service.
Jerry G.
Posted on May 14, 2008
SOURCE: Lens wont go back in, camera wont stay on
This is caused by the BATTERIES insert some top quality one better than durcell .
remove the memory card then do a reset which is the hole next to the trash can button you need a papper clip or a pencil shame the companys gone bust .
hope this helps
steve
Posted on Mar 02, 2009
SOURCE: I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Posted on Jun 17, 2009
  • 4 Answers
SOURCE: My camera turns on then turns back off right away!
Hi Most proberly the batery is shot. It wil be fully charged but it does not have "the amps" in this case miliamps to do the job. Pushing out the lens uses alot of the amps "miliamps" and the fact that it can't even rectract the lens back is a sure sign. If possible take the camera to a digital shop and test it with a known good batery!
Strongs
Posted on Aug 16, 2009
I dropped my camera whilst the lense was out and everytime i turn it back on the lense doesn't move it just says 'turn power off and on' and i turn it off, turn it back on and it still says the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
Everytime i turn My Kodak EasyShare camera on it says "insufficient bettery" Everytime. What do I do?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Cameras
I was Importing some pictures to my computer from my Canon sd 1300 is powershot digital camera , When the Battery died , I was not in the room at the time , So I came back in and attempted to turn the...
Since your camera is new the priviledge of your warranty claims must not be lost. So do not tamper to lose this benefit but call up the call centre of Canon for registeration/advice. What you can do is to remove the battery and keep if off . Since the battery is now fully charged you can reset the battery after some hours. There must some error that could have happened when the transfer took place, even a possible errror in memory from your PC. Hope you try. Good day
Aug 13, 2010 | Canon PowerShot SD1300 IS IXUS 105...
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 02, 2010 | Cameras
Strongs
Aug 16, 2009 | Kodak EasyShare M863 Digital Camera
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
I need help!
try to remove the battery and let the camera sit for a few minutes and reinsert the battery to reset the camera
Sep 02, 2008 | Kodak Easyshare M753 Digital Camera
My digital camera say lens error:21 how do i repiar the lens? sanyo vpc-e760 My SANYO VPC-S650 says lens error:507 everytime I turn the camera on. The lens has not returned back to normal position, and...
Jerry G.
May 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pentax Optio 50L Lens Error
Found this post - I have the same issue..
Anyone know about this?
Apr 27, 2008 | Pentax Optio 50L Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
