Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a dyt 4000. It was racing and trying to find it's speed than cutting out. I found a red wire feeding the carb that was grounding out. After I wrapped this wire in electrican tape I get nothing when I try to start it. It is not the seat switch. Is there a fuse somewhere?
  • timr356 Aug 03, 2010
    It is a Kohler comand 25 v twin
  • timr356 Aug 04, 2010
    Yes, I thought that there must be a fuse somewhere but I could not find it. The solution confirmed my belief and told me where to look
  • 435 Answers
There's a 20amp automotive fuse that is located in the main harness under the hood.
It should be easy to spot.
Posted on Aug 03, 2010
  • 1 more comment
  • Mike Raatz
    Mike Raatz Aug 04, 2010
    Did you find the fuse and was it blown?
    Yes, I blew 2 other fuses until I got the short fixed. That fuse is down on the bottom and hard to find. The connector to the carb was not making contact after I changed the fuse. I jumped it yesterday and everything runs. I need to change out this entire wire. I am assuming this is most of the reason for it loping.
    Big help awith good follow up
Putting devck belt on 48 inch cut craftsman DYT 4000
V part of the belt goes in the v pulleys. If the pulley is flat the back side of the belt goes against that. You don't need a diagram.
Jul 31, 2014 | Garden
95 Ford Escort Starter keeps running
it is the ignition switch is shorting out.
Dec 15, 2012 | Cars & Trucks
Can't figure out where to hook the idler spring onto the mower deck on my DYT 4000
look at the picture on the bottom of the foot rest there is a picture there
May 18, 2012 | Garden
Craftsman DYT 4000 with 26hp Koehler and 48" cut. Tractor will start but will not run smooth. Need to have the choke pulled out and once you push it in the motor shuts off. Will not start if choke is...
try running a can of seafoam through it. you have a clogged carb passage or two. sometimes this works. if not youll need to clean out that carb
May 14, 2017 | Garden
The wiring is incorrect on my Rand 4000, the red wire is cut off
Does it have a 220 plug on it,if so it is set up for 220,if not it is 120volt.The red and the white are hot/120 each,black is common and green is ground to metal.
Aug 07, 2009 | Coleman Powermate 60 Gallon Air Compressor
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
