Question about Refrigerators
Greetings. I own an older model frigidaire (FRS22WNCW)and the cooling systems seems faulty. THe Freezer section (side by side)works perfectly, while the refer side hovers at 64F and will not get cooler. I deforsted the coils to see if that would help, without success. Please advise
    Genius:
  • 1,073 Answers
You have a defrosting issue either the defrost heater the defrost thermastat or the defrost timer is bad only one is the problem
Posted on Apr 25, 2008
Frig side by side model glrs267zcq1 freezer cool but not frozen no ice
Hello friend, thanks for your post!
I see your Frigidaire refrigerator is not freezing in the freezer section but keeping your fresh food side cool. Some possibilities could be your refrigerator stuck in defrost mode, the control panel, or sealed system. I would recommend performing a reset on your appliance which would be flipping your household circuit breaker off for ten minutes. If that does not resolve your issue I would seek assistance from a professional to properly diagnose and repair your appliance. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
My frigidaire refrigerator does not seem to cool no freeze
If you have a sxs refrigerator then you have an issue with the damper door/switch not letting cool air from the freezer section to the refrigerator section. If you have a top mount freezer refrigerator unit, then you have a problem with the top venting system from the cabinet's ceiling.
Jul 27, 2012 | Refrigerators
FRIDGE SIDE WILL NOT COOL
Hi
This is usually caused by a clogged defrost drain. Many times vents between fridge and freezer sections are clogged with ice. Unplug the unit for 24 hours then plugin, and everything should work out.Also a faulty thermostat and Clogged/dirty evaporator coils (underneath in newer models, on back in older models) are the most probable reasons.Also All of the cooling in refrigerators is normally done in the freezer compartment. A fan circulates cold air from the freezer into the refrigerator compartment to cool it. Most likely this fan has quit working.
Please check the bellow link to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Samsung RS265LBBP Side by Side...
My Kenmore Model No. 10656596500 is having two problems that I can't seem to fix. The freezer is very cold and small ice crystals are located all over the place. The fridge side is not as cold as it used...
Greetings,
I would remove your freezer panel and see if the evaporator is blocked by ice..this causes air not to flow to refrigerator side...this is how they work..they also auto defrost this evap and if it skips a defrost. the end result is fresh food section not cold....also, make sure the evap fan is running....
Jan 11, 2011 | Refrigerators
Gibson/Frigidaire GRS20ZRH - Refrigerator section does not cool. Freezer cools OK. Water and ice dispenser is OK. Model is a side by side. Underneath coil/compressor section is clean. Please advise....
Check your fan that goes from the freezer to the refrigerator. It is probably faulty. If not then check your defrost timer.
I hope this helps
Please rate me
May 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
