Question about Frigidaire Refrigerators
Frigidaire side by side Mod. ED5LVAXW000, Ser. HRY1565596-- Ice will not dispense through door. The auger shaft does't turn when the motor is activated.
Krazytech
  • 725 Answers
SOURCE: Ice dispenser not dispensing
With your power going off your problem sounds like a dispenser control problem..you can check for power at the auger motor
38 5304430812 A B C Power Board
38A# 5304421617 A B C Switch-micro,single pole ,double throw
38C 5304430991 A B C Board-control
I would remove the dispencer cover and check the boards for burn marks
hope it helps
Posted on Jul 25, 2008
SOURCE: GE Profile Ref. Ice despenser motor does not turn. Auger turns
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
Posted on Dec 03, 2008
  • 37 Answers
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
Posted on Jan 03, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
aasc
  • 1606 Answers
SOURCE: Ice dispensing motor (IDI Motor) inoperative
Remove the ice bucket . Remove the 2 screws , holding the coupler on , on the door itself . Also remove the long shaft . The coupling is probably rusted onto the shaft . Remove the coupling , possibly with hot water or by tapping on a wrench , below the coupling on the shaft . When removed , a spring will come out also . Clean the shaft where the coupling goes , and put a light coat of grease or oil on it , so that the spring can push the coupling freely . Reinstall shaft , spring , and coupling .
Posted on Oct 02, 2009
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Model FRS26R4AB5 Frigidaire ice maker. Unit makes ice but will not dispense. When engaging in-door dispenser switch, I can hear the motor come on, but the auger does not move. This occurs even with the...
pull the ice tray out, you will see a silver thing in the back that turns the auger,, push the ice dispense button ( you might have to hold the door switch in) and see if it turns, if it does you need to replace your ice tray,, if it doesn't you will need to replace the solenoid or the motor itself
Jan 24, 2011 | Frigidaire FRS26R4A Side by Side...
Model GLH66EESB4 refrigerator. Makes ice but
Remove the ice bucket and auger assembly and hold the door switch closed while pressing the ice dispenser button to check for a dead motor. If it turns, try holding it with your hand to see if it can take a bind. If it will then your auger is the problem, if not it's motor time.
Mar 14, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice wont come out the door
Can you tell me if the auger turns and ice is just building up in the ice chute? I need to make sure we are talking about the model FRS6R5EMB so we are all talking about the same thing. The auger may be turning or may not. You can test that by opening the door, pulling the ice container with auger inside out and pressing the light switch in while someone presses dispense ice. You should see the motor turning the auger drive. If that works then we need to focus on the dispenser door if working or not, Let me know Thanks, Sea Breeze
Dec 21, 2009 | Frigidaire FRS6R5EMB Side by Side...
Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Aug 26, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
57 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
