Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Tractor cuts uneven, how do I correct it?. - Craftsman 20 Hp 42" Deck Lawn Tractor
  • 252 Answers
Make sure the blades are not bent , and stay the same hieight while rotating , ( do this while engine is stopped and plug disconnected your will have to physically look underneath - ie use a block and tackle to lift front end while you look physically turn them and try to make them move up and down / sideways and look for any un eveness in blade tracking
make sure the mandrell housing bearings are ok not loose
if mandrells brgs or spindles are bent they will need replacing
make spindles are not bent ?
make sure tyre pressures are 15 psi fr and 10 psi rear
make sure the the distance from floor to btm edge of r/h side of deck is the same as the l/h side adjust one or other until you have same measurement use tape measure ( this is side to side level )
then make sure you have rear edge of deck at the mid point about 5 mm higher than the front edge ( this is the rake ), adjust using the front draft arms or front lift link
make sure deck lifts evenly , you should see arms or lift links that connect to deck on l/h and r/h sides and at the front these will have some form of adjustment so deck can be levelled and rake set
if need let me know make and model and year and deck size of machine and i will try help further
cheers paul
Posted on Aug 04, 2010
Craftsman 1000 lawn tractor, very uneven cut
behind the plastic covers on the side of the tractor part there is adjustment nuts
Sep 15, 2012 | Garden
UNEVEN GRASS CUTTING
The most common cause of uneven grass is tire pressure of the machine. Even though they may look like they have air, when you go around a corner it may droop down on that side. If the mechanism is intact, there is no reason for it to change while riding. Or possibly you have a bent hanger.
Dec 15, 2011 | Garden
My tractor cuts uneven when i am cutting my yard
Check your blades common problem with uneven cut is a bent blade. Next find a level spot like a padio and take a torpedo level place it on the front center side to side not front to rear. On one side or the other you should see a J(jay) bolt with a nut tighten to raise losen to lower.
Terry
Aug 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven cut
I suggest you park the tractor on a level hard surface. Measure from the bottom of the deck to the ground on both sides of the deck to see if it is mounted level. The next thing to check for is a bent blade. Good luck.
Jul 06, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I sharpened the blades at the end of last mowing season. The next cut was very uneven, so I checked to make sure that the blades were installed properly and re-leveled the deck. The last cut was even...
The problem you discribe is the classic broken blade spindle or quill. The tube that supports the bearings between the deck pulleys and the blades is almost certainly broken. Look under the deck [mower OFF] at the piece right above the blade that is malfunctioning and you will probably find a bad bearing or a chunk of the tube that holds the bearing/blade to be missing. That happens when the blade gets 'wacked'. The outer edge is cutting too high because the belt is pulling the shaft toward the center of the deck. The quills are fairly easy to replace. Get the model number off your tractor before you go to buy the part.
Apr 04, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
