Question about Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI
I have a northern 3000 psi hot water pressure washer everything works but the burner will not fire up to heat the water
  • 50 Answers
If it gettin diseal to nozel it ur photocel r thermostat
Posted on Aug 03, 2010
What is the maximum water temp my machine can take?
The manufacturers do not recommend more than 120deg inlet temp. Overheating is a comon and serious problem for these high RPM direct drive pumps. Heat builds whenever the trigger gun is not pulled. Some pumps have special "hot pack" kits available, but even that maxs out at 160deg. Most real washers made for hot water, heat the water after the pump, not before. Special separate Hot Boxes are available for 2k or so.
Oct 18, 2012 | Honda Pressure Washer PSI 3000
The fan on the bottom of the burner continues to run even after everything is shut down
Okay!
just follow the power cord and unplug the damn socket from the electrical outlet!
Apr 27, 2011 | Cam Spray 25006QD* Q Series 2500 Psi...
Can i use karcha hose on a northern stsr pressure washer
Yes. Both brands use M22 (22MM) hose fittings. You will need to check that the Karcher hose is rated to a high enough pressure for your washer, especially if it is a thermoplastic hose as they tend to be rated for 2500 PSI.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 01, 2011 | Northstar Pressure Washer 3000 PSI
Diesel pump sprays and ignition coil discharges but No cumbustion?? please help
test compression in cylinder use a bit of oil remove igniter to do test also check to see if glow plug heats up
Jan 13, 2011 | Northstar Gas Powered Wet Steam & Hot...
Burner lights for a few seconds then goes out and wont relight mod # 1572251a
this could be a number of problems, first thing is replace the fuel filter
Dec 30, 2010 | Northstar Gas Powered Wet Steam & Hot...
Burner runs but will fire when trigger is pulled
the burner should fire (kick in) when the trigger is pulled,and switch off when you release the trigger.
Dec 28, 2010 | Northstar Gas Powered Wet Steam & Hot...
I have bought a diesel pressure wash but it only runs on cold. i have been told it needs a fuel pump to run on hot water. how would i fit one of these?
to have a hot water 170 deg+ or steam pres washer 220+ you for one need to have a pump and hoses/equipment rated to handle such high temperatures. Secondly you would need to add a burner to acheive that. You connect your water to the burner which then heats the water and pumps it to the pres washer. There are complete combos new for around 3k and up burner attachments by themselves normally start around a thousand dollars. You can check northern tool suplly website or any other for more detail. These are mostly used in commercial and industrial applications to remove grease,oil,solidified chemical residues and biproducts.
Aug 07, 2009 | Garden
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely...
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
May 08, 2009 | Northstar Pressure Washer 3000 PSI
Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI Logo
394 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
