Question about Philips GoGear HDD1830 MP3 Player
Windows 10 doesn't detect my mp3
It shows the connection on my screen but windows says it isn't connected. I've had this problem before and have gotten it replaced. I have no idea what's wrong. My player has frozen in the past as well. My dad reset the player but now I have no songs and can't get any on it. It makes me sad. I'd really appreciate it if someone could help me.
  • SilverOutlaw Apr 25, 2008
    My dad is the computer guy and has done as you said in the past. It has worked the first couple times but the next times we tried it it didn't. We'll try it again and hopefully it will cooperate. I think it's temperamental.
    Thanks for taking the time to answer my question.
    Genius:
  • Philips Master
  • 1,689 Answers
Try uninstalling the driver and software on the computer. Make sure that the unit is uninstalled completely. Re-start the computer and re-install it back according to the instructions supplied.
If it still does not work, I am very sure it is defective.
I would change it for another manufacture type if it is having persistant problems. Have you considered an original Apple, or a Sony, or a Panasonic? These are well supported big brand name units, and I have seen very few faults with these.
Jerry G.
Posted on Apr 25, 2008
Connect toshiba satellite l305-s5919 to tv with vga to rca cable
that particular model of computer l305-s5919 has RGB component out while the tv seems to be rca input.
does the tv have component in.
you may find an adapter like this might work
http://www.ebay.com/itm/Ypbpr-component-to-Composite-AV-RCA-audio-video-converter-with-power-supply/272260592065?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44770%26meid%3D75516a845eb841a3bec53062c7dfac66%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D230912528485
Jul 13, 2017 | Lifetime Computers & Internet
Recently I bought the Canon Ixus 220 HS compact camera. With the camera I received some software among other things Zoombrowser ex. Regretfully this program doesn't work properly from the start. When...
Is your Camera detected when connected to the PC via the PTP in the Device Manager? Check your "Device Manager". In Windows 7, sometimes the camera is not detected, but you can try "Workaround when the camera cannot be detected by Windows 7(when connected via PTP)". If the device is not detect in the Device Manager the software will not work.
The update is only for the software ie Zoombrowser(Win7x64) -> update to version ZoomBrowser EX 6.7.2 Updater.
Hope it helps & good luck.
Jun 08, 2011 | Computers & Internet
The device can not be detected in my computer
Hi there.... You can try other computer if they can detect the Sony Walkman that you have, if not being detected, have the device physically check.... if being detected by other computer, try updating the driver or software for that Sony device..
Thank For Using Fixya
Jun 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
My pc could not read the player therefore i could not open to view file what can i do
the player yp u2 when start 20% loading and still off.i ve trial to update my firmware but stil not detected it says please connect the device..i ve push play button....but still no detect ..any body can help me..
thanks
Nov 28, 2009 | Samsung YP-U2X Digital Media Player
Firmware upgrade needed for permanent solution
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Apr 26, 2008 | Apple iPod nano 2nd Generation MP3 Player
My computer don't found my mp3
The HDD1630 is only compatible with Windows XP and Windows Media Player 10.
If you have Windows Media Player 11, unistall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the HDD1630 to the power supply and connect to the PC.
The MP3 player should show as an MTP device. There should be a connection icon on the player screen.
Start Windows Media Player, and select the SYNC option to transfer music.
Feb 17, 2008 | Philips HDD1630 MP3 Player
Delstar mp3 ds 801
If you are running Windows 98 First or Second Edition, you may want to use the driver CD that came with your player and install the driver. If it is not supported by Windows 98 First Edition, upgrade to Second Edition. If you are using Windows 2000 or XP, you may want to check on the Device Manager to see if the player is connected. If the selected player shows an "?", it means you will need to update the driver. Run the Update Driver wizard, and install the player as removable disk.
Dec 28, 2007 | Delstar DS 917 Digital Media Player
Philips GoGear HDD1830 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
