Question about Dryers
Water tank full light on and dryer cutting out, no water in tank at top when i removed the access panel at rear micro switch has been flicked by float, i can empty this tank but same happens again
  • Marvin
    Marvin Aug 03, 2010
    I have no idea what you are working on here are what it is u are attempting to fix
    Sniper:
  • 174 Answers
I dont know make of your machine but there has to be a transfer pump somewhere. follow the hose back from the container at the top it will end up at the pump look for blockage or faulty pump.
Posted on Aug 03, 2010
The full tank light remains on even though the tank is empty. Is there a sensor which stops the dryer from restarting
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
The tank capacity is about 3.5 lt., enough for a drying cycle.
- Remove the screw (1) which secures the support micro and use a screwdriver for the two hooks which secure it to the sump.
- Lift them simultaneously and unthread the micro support towards outside
Putting upside down the support you can access the floating microswitch.
25069013-hcssld2gpo2sm22yg24xoxcy-3-9.jpg Inside the sump there is the float.
To extract it rotate the float 90° clockwise as shown.
Lift it up, rotate it towards outside and extract it.
While reassembling the pump, the float and the tank microswitch, repeat the same operations backwards, paying attention that when the micro support is remounted it is necessary to use a screwdriver in the fissure (indicated by the arrow), to lift the micro lever and lean it over the float (if this operation is not carried out the lever of the micro comes up alongside the float (it deforms) and the two components do not function anymore.
25069013-hcssld2gpo2sm22yg24xoxcy-3-20.jpg Dado
Sep 06, 2014 | Zanussi Dryers
How do I get to the door switch on a Whirlpool LDR3822HQ dryer
To access that door switch what ya need to do is firstly remove the top by removing the screws from the rear of it and slide the top toward the back then lift it off.then you see it the back side of the front panel at the top screws that hold the front panel to the remainder of the cabinet remove those screws and the front panel will come off where as ya can access the door switch.
GENE
Sep 30, 2011 | Whirlpool LDR3822HQ Electric Portable...
HOW TO GET INTO THE CABINET OF MODEL LER3622HQ0 WHIRLPOOL DRYER
You will need to remove the top panel, then the front panel in order to access the dryer interior on this model. With the dryer UNPLUGGED, follow these steps:
1. Locate the screws for the top panel in the REAR of the dryer. With the screws removed, the top panel should slide back, then lift off so you can access the screws holding the front panel in place.
2. Disconnect the door switch connector and any ground wires that may be attached to the front panel. Then, remove the panel screw on each side that holds the front in place. With the screws removed, the panel will lift up, then come off.
You should now have full access to your dryer interior. If you have any questions about this procedure, or if you need additional advice, please post back and let me know. I hope this helps you.
NOTE: There are helpful exploded view parts diagrams that can assist with disassembling and reassembling your dryer at the following websites:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
Aug 15, 2010 | Whirlpool Dryers
Light says tank full even though i have emptied it on tricity bendix tm310w
[unplug the appliance before proceeding] At the back of the dryer close to the floor there is a white cap secured with a spring coil lock. Use a pliers to loosen the spring and remove that cap [make sure you have a towel in place as there will be water]. After it has drained fully [you should tilt the dryer on it's left side when viewed from the rear and then tilt back towards you to get all of the water] replace the cap and secure it with the spring lock. Now tilt the dryer on it's left side and let it drop from about 5cm. See if that resolves the problem, if not remove the left side panel - when viewed from front [ you need to remove the lid by unscrewing the two retaining scrfews at the rear and sliding it back, then remove 4 screws from the back panel that connect to that panel, there is one more screw at the top front of the panel]. Unplug the two hose pipes [red and clear] and remove the small retaining screw then pull out the complete housing [it will slide]. You can then see the black float which triggers the tank full switch. Clean it and any other gunk that is in the reservoir. If there is a lot of dirt then you may have to clean your condensor [see operating manual for instructions on how to do that]. Put it all back together and the 'full tank' issue should be cleared.
Aug 10, 2010 | Tricity Bendix TM310W Electric Dryer
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Thanks
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
DRYER WILL NOT WORK
First check the electrical panel to your house. If it's a fuse panel check the fuses. If it's a breaker panel, reset it by flicking it off, then back on (do this even if it looks like it's already on).
If the dryer still doesn't work...
1) Check the door switch by pressing it in and listening for a clicking sound as you do so. If the door switch actuator spring is broken or if there is no click, replace the door switch assembly. This is done by removing the 2 screws under the lint trap screen and lifting the cabinet top. From there you can access the door switch. REMEMBER TO UNPLUG THE DRYER! You can also use a jumper wire on the door switch to verify it's function (unplug the door switch and connect a jumper wire to the 2 wires going to the console.
2) Check for a broken belt by lifting the cabinet top and visually inspecting the belt or by manually turning the drum from the inside (you should feel resistance or hear the motor turning).
3) Unplug the dryer and remove the back panel. On the heater housing remove the wires from the thermal cut-off and high limit thermostat and check the resistance with an ohm meter. If either of them are open (no reading) replace both (they come as a kit).
3) If everything checks out so far it may be the timer.
Feb 17, 2009 | Whirlpool LER7646E Dryer
Cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Oct 21, 2008 | Washing Machines
Tank full light stays lit.
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
Sep 22, 2006 | Tricity Bendix TM310W Electric Dryer
Dryers Logo
119 people viewed this question
Top Dryers Experts
Marvin
Marvin
