Question about Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
The ice maker/water dispenser doesnt work - Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
    President:
  • 1,099 Answers
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Good luck
Posted on Aug 03, 2010
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
mine did same thing. What is happening is the Water Line in the freezer door is freezing.
SOLUTION. Leave the freezer door open and turn off the freezer for a night. Be sure to dump out all of your ice cubes too.
In the morning it will work like new. To prevent it from happening again, open the FRIDGE door and use the electronic controls to raise the temperature of the freezer. You had it too cold before...thats why your water line froze in the first place.
Posted on May 02, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
Ice maker and water dispenser
If the refrigerator water dispenser is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 06, 2014 | Samsung 33 in. W 24.7 cu. ft. French Door...
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
My ice maker doesnt make any ice
check fill tube in back to make sure no frozen ice obstructing water flow... also make sure you have a clean filter on unit or it has been changed recently.... there are normally dual water valves on these models... one will work dispenser and one will work ice maker make sure your getting water to ice maker itself... if you are indeed getting water it just will not dump most likely you have a broken gear motor orthe heater in the ice maker has failed.. get another ice maker ....
Dec 31, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker doesnt work
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
twyw
Jun 04, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker working fine - Water dispenser nto doing anything
hi there,
sounds like the water valve may be the culprit.
can you provide the model # off your fridge please?
Sep 21, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
