Question about Linksys Wireless-G WRT54G Router
I have the linksys wrt54g-v8 router, pc keeps saying can not find router or keeps searching config forever, cables are connected properly.
  • Linksys Master
  • 7,733 Answers
Go to LINK
Posted on Oct 29, 2010
Computer says it is not connected (this is a second computer that is linked to primary computer with Linksys G24ghz router. It asks for a password I do not have.
If you forget your password, click on the reset button and re-config it, usually your WLAN won't work because you deleted all the config information, if you had this problem, connect it using LAN modem, and then write the router's IP usually it is 192.168.1.1 or 192.168.2.1 and then write the username: admin password: admin
Wish this was helpful.
Aug 13, 2010 | Linksys Wireless-G WRT54G Router
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
EasyLink Advisor says "Internet Connection is not working"
This alert is the adviser you do not need the advisor for this gear to work, Now the DNS comes from your ISP internet service provider witch most likely will nt help you with your router so you may be out of luck there but uninstall the advisor software and you should be in good shape. Now for the DNS that would be with your ISP a call to them will not hurt things ether. Good luck if you have trouble please ask for a chat its pretty cheap and will get the job done!! Have a great day!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 18, 2009 | Linksys Wireless-G WRT54G Router
I have V8 of this router and I need to hook it up to Time Warner digital phone service. What wires go where?
-take the Ethernet cable connected to you computer and put in the main port for the router( it will say internet) .
-get another Ethernet cable and and connect it to one of the ports with numbers underneath it.
- connect this part to you computer.
you will also need to set up you wireless router, linksys provided easy link which is an automated process to installing the router. http://tinyurl.com/kl94r8
Jul 18, 2009 | Linksys Wireless-G WRT54G Router
I can not get connected to router wrt54g
-->bypass the router first by connecting your modem directly to your pc using a network cable then try visiting some web site to check if you have internet connection if no go call your ISP but if you have internet connection try switching off your pc then redo and check your router config and connection.
-->if your connecting to your router through wireless try to check your wireless card if it is enabled. to check: go to start--->my network places--->view network connection. make sure the icon is enabled and connected.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys wrt54gs Set up
1. Unplug your cable/dsl modem.
2. Unplug your Router
3. Plug in your modem ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
5. Go to your 1st PC and get into Command Prompt. Type is ipconfig /release .... then type ipconfig /renew
6. Check for internet connectivity.
Repeat step 5 for for your second PC.
If your second PC is wireless go into the wireless config utility and search for access points. Connect to your Access point and check for connectivity.
If you still have no internet. Press the reset button on the back of the router for 45 seconds while it is powered on. Repeat steps 5 and 6.
Be sure to lock down your wireless SSID so neighbors and people passing by are unable to connect to your access point and do bad things on your network.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
