Question about Panasonic CT-30WX15 30" TV
No Sound One day everything was fine, the next day we didn't get any sound out of the speakers on the TV. I checked all of the simple things (volume level, no mute, and multiple input devices). I also tried to pipe the sound out of the TV into my stereo, but that didn't work either. I can only get sound if I run audio cables from my cable box directly to my stereo without going through the TV. Can I fix this? One item is that in the audio menu the mode area is greyed out (I cannot select anything).
  • computech99 Apr 26, 2008
    The sound is on. I put the option on for the speakers, and I also tried using the flow though to the stereo with variable and fixed output. None of them are generating any sound.
    Sound processor?? That sounds pricey.
  • Panasonic Master
  • 1,689 Answers
Check to make sure that the sound option in the TV is not turned off. I am assuming you want to have sound out through the TV set.
Other than that, there may be a failure in the sound processor or anywhere along the sound path in the TV set. This is not something you would be able to service at home yourself.
Jerry G.
Posted on Apr 25, 2008
RCA model# L46WD22YX11, TV works, Sound bar on screen moves but no sound. Any suggestions.
Check the speaker/s first. If found OK, check and replace the audio output IC. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 18, 2015 | RCA Televison & Video
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 04, 2011 | Computers & Internet
We were watching tv last night and everything was fine. All of a sudden the sound disappeared. Everything else is still working fine except the sound. Any ideas?
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Hope this will help out in solving the problem...
Jun 30, 2011 | LG 32LG30 32 in. LCD HDTV
Have an RCA RTB 1023, blue rays have played fine until I played a movie last night and the voices echoed? What causes that??
A common mistake with this type of setup can make for a frustrating solution, until you realize how silly and simple it is.. I'm going to take a stab in the dark and say you have this system connected to your tv through an HDMI cable, correct? If so, please nod! Now that you've just finished nodding your head up and down at a computer screen, have a little chuckle and now we'll continue! :-P Your HDMI cable is special because not only does it deliver magnificent picture to your tv, it also carries the sound from your player to your tv as well as playing through your surround sound speakers! So here is where the fun comes in, depending on what you may have been watching on your tv that particular day, the volume level is bound to fluctuate, because of a little know fact that not all tv channels use the same sound output level as others... Ooo you've learned something new, pat yourself on the back and here is your simple solution. Next time your watch a dvd on your system turn the volume on your tv up up up, and down down down, some times there is a slight lag from the audio being played on your tv speakers than on your surround speakers. So when in doubt, just turn your tv speakers all the way down! :) enjoy
Jan 10, 2011 | RCA RTB1100 Theater System
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
No sound on Logitech Z Cinema 2.1 speakers.
1. Check Output cable properly connected to the computer in Green socket.
2. Check computer Volume Balance.
- go to start- control panel-sound & game controller
- check ur volume mute/unmute, volume all balance
3. check sound drivers/update driver
- go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
- Then Scan in device manager. it will automatically install again.
4.Then check output volume.
Feb 01, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
My blaupunkt rear right speaker just stopped giving out any sound started with a tearing sound at high volumes with bass intensive songs. then next day no sound at all. left speaker works fine. Help...
As shown in the picture double check the vibration flexible wire connecting to the center, you cannot see it on your naked eyes, use tester to prove the connection, use soldering iron to reattached the broken circuit, be responsible for the connection, put in mind that it is vibrating too heavy...
Oct 21, 2009 | Blaupunkt GTx 693 Coaxial Car Speaker
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
Panasonic CT-30WX15 30" TV Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
