Question about Garden
Runs when choked. cuts out on full throttle. Is there a carb adjustment?
    Problem Solver:
  • 10 Answers
Yes there is but most of the time u don't need to mess with it just take the carb off and clean all the jets with eater gas or carb cleaner and that should fix the pro
Posted on Aug 04, 2010
I have a Stihl MS 181C. It starts, no problem, but the chain runs on tickover and when I squeeze the throttle it cuts out. Can you please advise.
fuel filter --air filter --bad fuel--carb /cleaning /rebuild /replace-fuel line - binding clutch--tension to tight on chain
Aug 14, 2017 | Stihl Garden
95 suzuki 250 quad king, at full throttle it runs at half power, choke seems inop
First make sure your choke circuit is working. May be an indication that your carb needs to be cleaned. I wouldn't replace it yet= clean it. If the choke circuits and the carb check out fine. An unresponsive motor/ carb usually means bad valves or valve timing. Example: it runs rich, spits fuel out the carb no matter how lean you set it. Even with the idle air closed it runs rich... intake valve is not closing or closing late. In that case it needs valves serviced.
Aug 26, 2014 | Motorcycles
Dies when you turn off the choke
sounds like you have an air flow issue,remove carburreter strip andclean with carb cleaning spray and an airline. Check float height adjustment, once everything has been reassembled, refit carb, prime with fuel and JOB DONE
Mar 05, 2013 | Yamaha Timberwolf 250 2wd 97 Airbox Air...
Craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Oct 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Runs only on half choke
Before you take it a part adjust the fuel air mixture most of these small engines are air 1 1/4 and fuel 1 turn get it to ideal just before the foot spins ( let the engine warm up good and have fresh fuel before doing these adjustments) afer a good ideal adjust the mixture for a full no bogging speed . If this does not work then start to work on the carb.
Jul 20, 2012 | Garden
Honda snowblower, starts well, and runs smoothly on idle, however on max throttle it cuts out; the choke part of the throttle seems to work fine too. Any idea what the problem is?
give it a little throttle, just before it cuts out. and adjust the carb, screws for best performance. if it will not run good after the adjustment. then the carb needs rebuilt, it may have dirt in it! good-day !
Nov 02, 2011 | Motorcycles
Ok i just got a 2004 crf 70. i have taken carb apart twice and cleaned every jet ect... problem is when wide open it cuts out spits and spudders. I have changed settings on throttle cable and swapped out...
Could be that you need to go up one jet size.
When choking a motor, your richening the mixture with more fuel, less air.
So if you must choke it, you must need more fuel.
As for electrical. some bikes have a rev limiter when you hold the throttle wide open You may be reaching the rev limit.
A rev limiter with turn the power on/off the coil superfast, keeping the rmp at a maximum factory setting, and the motor breaks up at full throttle.
Some cdi's have and adjustment that you can set your own rev limit, or you can buy a cdi with no rev limit.
Hope this helps
Dec 09, 2010 | Honda CRF 100 F Motorcycles
Just replaced the carb, fuel lines, filter and gasket that goes between the carb and cylinder wall. All brand new parts. I believe lines are connected correctly. Now the engine runs like it is on full...
I don't think it has anything to do with the high/low settings, but in case was the carb pre adjusted or did you adjust them yourself. Did you put the throttle cable in the right hole on the throttle plate if there is more than one. Check the idle speed screw (not the low needle) to make sure it is not causing this. Look to make sure the throttle butterfly is not binding in the open position or that the throttle cable itself is the culprit. Maybe your gasket moved when re-installing causing plate to stay open. I suggest removing carb and inspecting for any of these problems. Maybe there is something wrong with your new carb! I hope this helps out. Happy to answer any questions.
Dec 03, 2010 | Craftsman 25cc Gas Line Trimmer
Ryobi straight gas trimmer, runs rough at idle and up to 1/2 speed, but great at full speed. Bought a reconditioned one.
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
* For this specific problem, i would say you should probably just adjust the "L" screw and hopefully that will help
Apr 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
