Question about Bose 32022 CD Player
Bose am fm single cd disk player, the problem is with the cd player, it takes the cd and won't eject or play was able to take out the cd with tweezers twice before but just bought a brand knew cd and it ot stuck and I can't pull it out like before
  • 1,557 Answers
The problem with these machines is very common as they run on the old belt drawn cage over time the belt stretches and can no longer break the clamp holding the disc in place it just keeps slipping. the fix is simple just take the unit apart and replace the small belt they cost around $ 6 the problem is getting the unit apart as they a more tricky than a simple standard dvd player but its worth a shot just remember what goes were.
best of luck to you.
please take the time to rate this repair thank you.
Posted on Aug 03, 2010
How to remove cd stuck in player
Remove cd player and insert small tool to release stuck cd. Otherwise dissassemble cd player and remove.
Take to audio store and have them reome the cd.
Mar 20, 2015 | Jeep 2006 COMMANDER Radio a1z115973...
Cd stuck
Did you try resetting it?
Jun 04, 2008 | Bose & Wave& Music System
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
CD won't play
Sounds like the disk has not finalised correctly. Computers can play CDRs when they are only partly completed as they search the disk fro the files. A CD player expects to find a Table of Contents to tell it where the tracks are and if this has not written correctly it will not play on ordinary CD players but will work in computers.
Regards, Andrew
Sep 11, 2008 | Audio Players & Recorders
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Aug 22, 2008 | Bose Acoustic Wave (32022) 5-Disc CD...
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Cd stuck in player
    I realize this post is a little old , but for anyone looking for a solution try disconnecting your negative battery terminal for a minute or so then reconnect. Next try to eject your cd. Worked for me ^^
    2001 taurus
    Feb 13, 2008 | Car Audio & Video
    Bose 32022 CD Player Logo
    152 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
