Question about RIM BlackBerry Bold 9000 Smartphone
I am having problems getting pictures send to my Blackberry 9000 via Bluetooth from Nokia and other phone devices. Even though the device is paired with my Blackberry sending pictures fails (with error "Sending failed").
    Problem Solver:
  • 9 Answers
Hey hi...may b i can solve ur problm...
1st open d media application,then lighlight the picture folder by putting the cursor on it.next click on the menu of the picture folder.....there u will find a option "receive through bluetooth".click on that.ucan receive ur files nw.
(Note:-u mst 1st swith on ur bluetooth and must have paired wid the device 4rm which u wish to receive data)
only after clicking on the "receive through bluetooth" the data must b send 2 the blackberry.....
hope u got it....
u can contect me at zeebonbarua@gmail.com 4 quarries..
gud luck
Posted on Aug 07, 2010
I bought my son a blackberry curve 8250 a few days ago. I cannot send any files to his new phone via bluetooth, even though the phones do pair with each other. Please help!
When you send over bluetooth on a blackberry and the handset pairs you need to select the file type you are send and be in the folder to received. Once in that folder you need to click the blackberry key and select received via bluetooth.
Feb 19, 2011 | RIM BlackBerry Bold Smartphone
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Bluetooth headset pairing won't go away
you can disable blue tooth connections from the connections manager
Jul 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Want to send picture from phone to computer
Can you not use bluetooth to send pictures from phone to computer. Search on your mobile phones menu to see if there is bluetooth and enable it. If your mobile is not bluetooth enabled, you may still be able to send pictures from phone to pc if there is a USB cable slot in the phone. To send to the pc via bluetooth, either your pc has been set up with bluetooth, or, if not, you have
to install bluetooth using a bluetooth dongle which comes with CDrom, and may be purchased from computer stores like Currys or online for £10-15. Let me know if you have bluetooth, and I'll help you more. Once there is Blue tooth it needs to be turned on, and discovery mode has to be enabled, (not disabled) in order to communicate with other nearby bluetooth enabled devices. Get back to me tell me what you found out, Good luck papertigers
Dec 13, 2008 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
226 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
