Question about Garden
Using a Dixon Ram 50. Made a noise like I hit something. Shortly after that, It made the noise again and I knew I did not hit anything, I shut off the machine and raised the deck to inspect underneath. The blades were not restricted and seemed to rotate fine. I got bacl on and it made the noise again and then I noticed that ant time I was in longer grass, the tension applied to the mower deck rotating pulleys would decrease significantly. Somtimes even come to a stop.
  • 48 Answers
SOURCE: Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Posted on Oct 17, 2008
  • 6 Answers
SOURCE: need help installing drive belt on lawn
look at the back and see if there is a lever.
it might solve your problem.
Posted on May 10, 2009
darjr
  • 378 Answers
SOURCE: My engine runs fine, but
check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
Knooking in bottom of engine for an 1985 dodge d50
bottom end noise usualy the knock of death for most engines
tap noises are lifters knock is crank or rod bearings. driving will only spin a bearing or weld it to the crank
if the truck worth it...used engine from auto wrecker
or spend that money on new ride
Feb 02, 2012 | 1985 Dodge Ram 50
Loud roaring noise coming from 2000 blazer. It only does it after driving for a few minutes at about 60 mph. After that, it will continue to do so until I shut it off. When I start it up again, it sto
could be a bad pinion bearing or something of that nature
our truck had the same thing happen,it only did it in 2 wheel drive not 4x4.....it was the transfer case
Jan 13, 2012 | 2000 Chevrolet Blazer
I have a dixon ram 50 and it will not cut taller grass without the belt slipping. if i were mowing a golf course it would be fine. very aggrivated with the dixon. and the belts are new just got it back...
there is a bar that gose from the front of the deck to the height adjustment bar it has a pine in each end of the bar. disconnect it from the bar and tie it to the deck. this bar is only to be used when changing the drive belt
Aug 05, 2010 | Garden
There is a loud noise at 45mph.
Find a quiet empty stretch of road. Go 50 mph, put the trans in NEUTRAL and shut the engine. If noise is still there, swing car left and right to detect noise differences. Could be hub or axle bearings. Not engine or trans if noise is still there. Hope this helps
May 05, 2009 | 2004 Chevrolet TrailBlazer
Dodge ram 2500 transmission makes noise that comes and goes.
sounds like inspection cover to trans hitting flexplate
Mar 19, 2009 | 1999 Dodge Ram
Replaced the alternator on a 96 RAM 2500, now the truck shuts off
Dodge computers reset if you unhook the battery so the truck needs to relearn how to idle and run. Help to truck idle for a while and it should start to do itself after about a minute
Dec 25, 2008 | 1996 Dodge Ram
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
