Question about Fiskars Brands Fiskars Hedge Shear
I have a Wallace hedge trimmer by Fiskars. It is a Power Lever model 10HS. The pin that holds the blade and power flange together has come out and was lost. Do you have another or what can be used as a substitute? The head must be flush with the blade so that it clears the other blade when it is being used.It looks as if the hole in the blade is made to hold a bolt, rivet or other part in a recessed hole. The part on the other blade looks as if it might be a press fit into the two parts.
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Defective hedge trimmer with a lifetime warranty. How do I file
Contact Us, Warranty and FAQs
We want to hear from you! We are always looking for the best way to stay in touch with you. If you cannot find what you're looking for, feel free to call us toll free at the number below. Our customer service specialists are available Monday – Friday 8 a.m. to 5 p.m. CST, excluding national holidays.
1.866.348.5661 WARRANTY CLAIMSTo request a warranty replacement, please either:
  • Email warranty@fiskars.com with a SINGLE photo, showing your whole product in the picture. Please make sure we have your full name, mailing address (no PO Boxes) and telephone number.
  • Mail your defective/broken item OR a photo of your defective/broken item back to us:
    For Garden Products:
    Fiskars Brands, Inc.
    Atttn: WARRANTY DEPT
    780 Carolina Street
    Sauk City, WI 53583
    USA
    Hope this helps.
Posted on May 06, 2010
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
My electric hedge trimmer blades do not move when it is turned on. Suggestions? hs2400 date code 20021249
Check that the bolts or screws holding the two blades together aren't too tight preventing the blades sliding. Lubricate the blades also with WD40.
Jul 14, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Engine runs great, accelerator responds perfectly, but the blades stopped moving. Any ideas?
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Apr 30, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I cannot seem to close the hedge trimmer again: i.e., the tips of the two blades do not come together again. How can I solve this?
Evidently there is a burr/dent along one or both of the blades that is causing it not to close all the way. Just take a fine metal hand file and lightly file the area of the dented blade on the bottom of each blade, the sides of the blades that face each other. When you do one blade, just flip the trimmer over and do the other blade the same way. That should eliminate the problem and let the blades close all the way again.
Apr 25, 2011 | Fiskars Brands Fiskars Fiskars Powergear...
Blade moves back and forth,but won't cut anything
Check the bolts or screws holding the blades together are tight but not so tight that they cant move.
Ensure blades are sharp.
Feb 02, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
Blades locked up
Nov 07, 2010 | Echo 24 In Double Reciprocating Double...
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
    780 Carolina Street
    Sauk City, WI 53583
    USA
    Hope this helps.
May 05, 2010 | Fiskars Brands Fiskars PowerGear Hedge...
I wish to know if I can purchase new blades for my hedge trimmer model number 900.799740 . Can I replace blade with 22 inch or longer size? Can original blade be sharpened? What new model is compatable?
Go to www.partsdirect.com, this is sears website for parts. You should be able to find the part number for a new blade.
If the blade has bolts and nuts holding the blade together it can be sharpened. If it is riveted together, it can be but it is more work than what it is worth.
Sep 25, 2009 | Craftsman Garden
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
Fiskars Brands Fiskars Hedge Shear  Logo
98 people viewed this question
Top Fiskars Brands Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Fiskars Brands Garden Expert? Answer questions, earn points and help others
