Question about Car Audio & Video
Is a 760 watt pioneer amp supposed to get hot if it is bridged
Mine does too...
Posted on Feb 09, 2011
Amp pioneer 760 watts keeps blowing both 30 amp fuses when volume is raised
remember this amp when bridged can only go down to a 4 ohm load so if your subs are putting a load to the amp that is anything below 4 ohm than your going to have issues. is used as a 2 channel each channel can to 2 ohm but when bridged 4 ohm and above.
Aug 12, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    What kind amp should be use for ts-w307d2 subwoofer speaker?
    Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
    Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
    There is no sound coming from my 15's when my stereo is on
    it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
    Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
    Hits intemittently
    ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
    second make sure you have the impedence correct "possitive to positive negitive to negitive'
    hope this helps
    Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
    Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
    never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
    Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Speakers
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Car Audio & Video Logo
    29 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
