Question about Refrigerators
HELLO WELL IT GETS VERY HOT ON THE SIDES & TOP WHAT DO YOU TINK IS THE PROBLEM
    President:
  • 1,430 Answers
The condenser coils are dirty or the condenser fan has failed. The condenser is located down behind the fridge near the compressor. Here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Posted on Aug 03, 2010
Just replaced water pump now there is a ticking sound when it gets warmed up
Ticking sounds can be two things.
regular soft tick is the join in the drive belt as it goes around the pulley. As you have replaced the pump, you have tightened it.
Irregular tink, tink sounds are aluminium cooling.
Sep 14, 2015 | Cars & Trucks
My frigidaire is getting cold thn gets hot both sides. what could it be?
Hello friend, thank you for the post!
Based off the information you have provided the sides of your refrigerator get hot when the unit is cooling. The reason this could be happening is when your appliance is being cold down by the compressor it is putting off heat, the heat then rises up and out which come into contact with the sides of the refrigerator. This is a normal operation of the appliance. Hopefully this is helpful. -Matt
Aug 08, 2014 | Frigidaire Refrigerators
The top & sides of freezer outer housing getting quiet hot,but only near the door,ps-have the red light alert & rest seems ok,so going to try the defrost stuff.
If you remove the rear panel inside the freezer and examine the evaporator while running you will most times see a few rows of the evaporator with clear ice and the rest will be sweating water droplets. That is what a leak in the Freon will cause and look like. When the door frame gets hot it is sometimes caused by a defective condenser fan or blocked air flow and also reduce cooling. Warm is normal around door frame because you have hot gas flowing there to reduce sweating around doors. I will be here to answer any questions you may have, Thanks Sea Breeze
Aug 22, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
My Fisher&Paykel Dryer gets really hot on the top and upper left back when only running for a short period of time. what is the problem?
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 13, 2011 | Fisher and Paykel Dryers
Does outer cover of stainless steel microwave get hot usually
The top gets the hotest as the heat from the cavity must get out through vent holes in the cavity. The sides will get hot if not adequate air flow is available.
Hope this helps.
Dec 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Metal of stove gets very hot both on the sides and
get this stove checked out,sounds like a blocked vent or a faulty thermostat.adrian;;;
Dec 02, 2009 | Amana RanARG7302 Gas Kitchen Range
My amp gets really hot as soon as the power comes on. what does that mean
Check your speaker output cable and connector, they might have connected to body of car.
  1. Remove all input / output cable from amp
  2. Plug the power into amp.
  3. if still the amp is still heating.
  4. Check if any screw used to fix is not connected any part of the amp output or input point.
Jul 22, 2009 | Kenwood KAC-728S Car Audio Amplifier
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
