Question about Jl Audio 500/1 Car Audio Amplifier
I hooked up the 500/1 amp and when the bass hits it turns off where can i get it fixed or how do i get it to stop doing that i live in fontana ca maybe you have a shop near by
    Problem Solver:
  • 7 Answers
Check your ground connections. Alot of times when the amplifier is pushed to its higher levels of power if it doesnt have a solid ground connection it will kind of choke itself. Also with the amplifier you should make sure there are no knicks or anything in the power cable. Make sure you are running a 4awg power and ground cable with solid and clean connectors on the ends. Also that amplifier needs a good anl fuse holder with at least 100 amp fuse.
Posted on Aug 08, 2010
Amp shuts off.
check the connection of power connection and the remote connection tone amp,you can check also you inside by using your hand ,turn on the amp and wiggle it the power connection parts.
Jun 15, 2013 | Jl Audio 500/1 Car Audio Amplifier
Subs stop producing sound when stero volume is turned up
make sure your wiring is correct.. negative to negative positive to positive.
Oct 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Gain conrol problems
relatively simple 2 leg pot. fix.
Under $50 to repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Jl Audio 500/1 Car Audio Amplifier
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
Mar 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Low ohms light flashes and bass distorts at high volume
Sounds like you need to invest in a capacitor. Those are used when subs receive a bass spike. You just a need a 1 Farat Capacitor (1,000 watts) ran between the head unit and the amplfiier to fix your issue. Also, try reducing the volume gain to half gain and low pass frequency to half gain; this will increase your clarity and make your amp less hot. This may fix it without a capacitor. Also find out what amprage your alternator is. Your alternator may not be designed to run the amplifier. Most alternators are 200 amps now if they are gold plated.
Hope this helps
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 10, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
80 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
