Question about Honda Garden
Got new camshaft for 5 hp honda motor need to know how to set timing to put belt back on thanks
  • 50 Answers
Is that engine not push rod
Posted on Aug 03, 2010
Why does honda has no compression after putting in time
One of two things, if it broke the timing belt and is what is known as an interference engine then the pistons can hit the valves and bend them causing no compression, otherwise be sure to check all timing marks to be sure your crankshaft and camshaft are in time with one another. Hope this helps.
Feb 27, 2016 | Honda Cars & Trucks
I just changed my water pump and timming belt on my 1995 accord it is a 6 cyl i have the crank and one camshaft lined up but cant get the back camshaft to line up
You need to re-do it: take the belt back off. Now turn the crank counter clockwise, just a little, maybe 3 notches, to put all the pistons down just a bit in the block. Now set both camshafts on their prospective marks, then move the crank back to TDC. Place the timing belt back on and rout and set as per manufacturer's instructions. Hope you get it this time. Also hope you have a manual to refer to. If not, better check the procedure-some allow only a certain way to set the tension assembly to get proper tension on the belt. Good luck.
Mar 18, 2013 | Honda Accord Cars & Trucks
1991 Mazda Miata 1.6l timing belt broke.
You need to purchase a Haynes Manual or better. They are very common in your nearest chain part store. Like Autozone, Advance, Napa. More than likely you will have to set the crankshaft at TDC. "top dead center" and allign the two marks with the cam shaft! Watch when you put tension on the belt it will move the camshaft sprocket! And throw it back out of time.
Jul 13, 2012 | Cars & Trucks
I own a 2004 accent with 122,000 km on it. Long story short, had to get a new head gasket put on, so rocker cover, cams, everything had to come off. Work was done and everything was put back together. I...
P0340 - Cam Timing
SYMPTOMS/CONDITIONS
of a mistimed camshaft system (all must apply):
  1. Camshafts have previously been removed from the engine.
  2. Engine runs rough.
  3. Vehicle sets P0340 (camshaft sensor code).
  4. Camshaft sensor has been checked with a known, properly operating camshaft sensor.
CORRECT:
The diagram in the manuals should show the timing marks on both cam gears to be on the blue timing chain links.
Mar 23, 2011 | Hyundai Motor 2004 Accent
Timing belt broke and i need to set the timing
The pistons, valves and cylinder walls typically take a beating when the timing belt breaks. If yours didn't, I'm amazed.
But you can TRY this:
For most OHV engines with a timing belt there is usually a hole in the camshaft sprocket that can align with a hole in the head. If there are two camshafts, each sprocket typically has the same arrangement. Look closely, if there is no hole, there will be a mark of some kind to indicate #1 Top Dead Center.
Make certain that the crankshaft and the camshaft(s) are all at #1 TDC, if there are holes in the sprocket(s), push an appropriately sized drill bit through the hole, into the corresponding hole in the head to hold the camshaft timing, then replace the belt, making certain that any idler pulleys or tension adjuster pulleys are out of the way. After you've put the new belt on, Put the idler pulleys and tension adjusters back into their appropriate place then remove whatever you used to hold the pulleys in place.
Most of the time a valve will "kiss" a piston when the timing belt breaks. That causes immediate and fatal damage to the engine requiring (at minimum) a complete engine rebuild. Sometimes valve seats, pistons, cylinder walls and other components are destroyed when the piston and valve collide.
Feb 27, 2011 | 1992 Honda Accord
1995 Honda Passport timing alginment 3.2 ltr 6VD1 engine
The crankshaft should have the timing mark on the crank pulley (Notch in the outer edge of the pulley near the keyway) It should align with the timing mark on the oil pump. (With the keway turned to about the 3 O'clock position.)
Align the marks on the camshaft timing pulleys with the corresponding dots on the front plate.
If you are installing a new belt, it should have 2 solid white lines printed on it that you would align with the timing marks on the cams and a dotted white line to align with the timing mark on the crank.
It makes a difference which way you put the belt on. (Which edge faces the front of the engine.) Most, but not all brands of belts have arrows and the word "FRONT" on them to tell you which edge of the belt shoud face the front of the motor. If there is no mark to tell you which edge is front, the letters on the belt must be able to be read correctly as viewed from the front of the vehicle.
Oct 30, 2009 | Honda Passport Cars & Trucks
1989 honda accord oil leeak cam/crankshaft
Take valve cover gasket bolt out replace... An when you do the lower crank seal you have to take off oil pan.. Big job but it can be done..
Jun 27, 2009 | 1989 Honda Civic
Trying to set timing belt (new )
Be very careful with this timing belt change.
The key setting is to get the crankshaft and camshaft properly synchronized !
I believe this is an "interference" engine. If the crankshaft and camshaft are not set properly the valves will hit the pistons and be bent ! That would destroy the engine.
DO NOT TURN OVER THE ENGINE UNTIL THIS IS SET CORRECT
No you will not hear the valves hitting the pistons - you will hear the engine turning over faster than normal because you have lost compression.
The engine has marks on the gears and pulleys that will align with marks on the engine block at TDC which should be done before the timing belt is removed ! If you have did not do that and either the crankshaft or camshaft has moved, you have a problem. You can get a manual from the library, auto supply store, eBay or a manual seller.
Putting on the timing belt could use an extra set of hands- when you line up
the marks and the engine is at TDC, the injection pump has some spring tension
and will jump back one tooth. this means you have to hold the pump pulley in
place while putting on the belt. so an extra set of hands makes things much
easier.
Apr 26, 2009 | Toyota Highlander Cars & Trucks
My escort van is out of timing need to set timing again
YOU NEED TWO 6MM DRILL BITS, THERE ARE TWO HOLES TO PUT THESE IN, ONE ON THE CAMSHAFT AND THE SECOND ON THE PUMP. SLOWLY TURN THE ENGINE BY HAND UNTIL THE TWO HOLES LINE UP WITH HOLES BEHIND THEM, THEN PLUG WITH THE DRILL BITS. ITS NOW SAFE TO REMOVE THE BELT BY TAKING OFF THE TENSIONER AND LOCKING OFF. PUT ON THE NEW BELT AND RELEASE THE TENSIONER SLOWLY AND REMOVE THE DRILL BITS. TURN THE ENGINE BY THE NUT ON THE CRANK SHAFT A COUPLE OF TIMES. THEN PULL BACK THE TENSIONER ALL THE WAY, THEN LET IT GO SO IT SNAPS AGAINST THE BELT, IT IS NOW TENSIONED AND JOB DONE
Feb 28, 2009 | 1999 Ford Escort
Garden Logo
124 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
