Question about Refrigerators
My side by side fridge door does not close by itself when released
  • 3,289 Answers
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Posted on Aug 03, 2010
Top door will not close by itself on fridge
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Nov 28, 2014 | Electrolux Refrigerators
Fridge doors do not close completely
1st ckeck that nothing is sticking out just far enough to pop the door open.if not that, than the gaskets can were out on frig doors , you can order it on line from all appliances, get the model # from inside the frig , be patient installing it , its tricky, but it can be done by Harry homeowner. good luck.
May 04, 2012 | Maytag MSD2756GES Side by Side...
The big door on my side by side will no close by itself.
That is because the refrigeator is not level...
Use the adjustment features for the legs of the fridge to level it and then the door will close...
heatman101
Feb 15, 2011 | Whirlpool Refrigerators
Door does swing closed so it remains slightly open about half the time when the last person could have sworn they closed it. Hubby tried to adjust hinge but it did not make a difference. The fridge is only...
There should be a way to level the feet of your fridge so the door swings closed by itself. Check the user manual that came with your fridge for advice on how to do this on your fridge, as each make and model of fridge differs. This technique to level a fridge on the floor is generally necessary because the floor where the fridge is placed is unlevel, and it does not imply any fault with the fridge itself.
Jun 08, 2010 | Kenmore 53642 / 53644 Side by Side...
Fridge door does not close on it's own. possibly missing spring.
There are no springs to assist refrigerator doors to close.
The fridge doors can be made to close themselves by adjusting the height of the feet of the fridge. "Pitching" the fridge slightly away from the hinge will accomplish this. If the foot on the hinge side of the fridge door is slightly higher than the foot on the handle side of the door, the door will usually want to close by itself. If the fridge is a side-by-side type and this is done, one door will close by itself and the other will want to remain open (or open fully). In this case, it's best to have the fridge as close to level as possible.
I hope this was helpful.
Nov 28, 2009 | Amana Refrigerators
Door does not close by itself
the only way to get a refrigerator door to close by itself is to adjust the legs so the hinge side of the fridge is a little higher than the latch side.
Aug 16, 2009 | Refrigerators
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Flap on refrigerator door will not close
You will need to replace the solenoid kit for door.Call us 704-819-6557 same day shipping
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
