Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
    Scholar:
  • 97 Answers
When the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Posted on Aug 31, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
It will start for a minet then shut off and wont start till it sits for a half hour
Check to see if the fuel filter is clean or change it. If the screen in the bottom of the gas tank is clogged, that will do it too. If those solutions do not work, check the oil level and condition of oil, if it is low or dirty the low level switch will shut it down.
Jan 21, 2013 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 5000 gen. starts fine then dies like it is running out of gas. new fuel and filter is good. getting good gas flow.
Sounds like you may have a stuck float. It is inside a cup that hangs down under the carburator, there should be a nut and a serrated screw adjustment value. Put a empty coffee can under it to catch the gas and remove the nut the cup will fall off into your hand, you will see the float make sure it moves up and down on it's own weight. Sometimes they get old and stick it is held in place by a small pin (don't loose the pin) unscrew the adjustment pin counting how many turns it tales to remove, clean every thing with carberator cleaner, you may have to buy a new gasket for the top of the cup, they are very thin and break easily. Reseat the gasket in the groove it came out of, put the cup back in place and put the nut back on just an-off to make it good and snug, screw the value pin back in place counting the turns so it sits were it was before. Make sure the gas value is open and try to start the engine, at first it will fill the cup with gas then it should start up. If not you may have to disasseble the caberator and clean all the tine little ports, I have one that was so bad I just had to replace the caberator.
Apr 18, 2011 | Coleman Powermate Powermate 5000W...
After a few years in storage (no fuel in tank or carb) and new oil, gas and plug, it will not start. No spark
There's a oil level sensor on that gen,if it doesn't "see" enough oil it grounds out the ignition.This is to keep you from destroying the engine due to no oil.If that's not it re-post and we'll try something else?
Jan 14, 2010 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate on/off switch broke off. Is a DIY out of the ?
there is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
461 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
