Question about Kenmore 57029 Side by Side Refrigerator
Frost in the freezer - Kenmore 57029 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
Posted on Aug 12, 2010
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Frost freezer
On humid days, when you open the freezer door this moist air enters the freezer, then freezes to form frost. Try not to keep the freezer door open for very long. There is really nothing that can be done to prevent the frost. If the problem is much worst than in the past, check the seal around the door for any cracks or holes. If it is defective, replace it with a new seal.
Aug 30, 2015 | Frost Refrigerators
Why would freezer produce frost?
All freezers produce frost. Some automatically "defrost" at intervals. Perhaps your freezer has stopped doing those?
Jul 09, 2015 | Frost Refrigerators
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Aug 18, 2014 | Amana Freezers
Items in freezer are gathering significant front, when the freezer should be frost free
A frost free freezer typically relies on a "fan" to vent that area of moisture. So, if the fan/vent is not working properly, the moisture in the freezer stays and become frost. Frost can also form if / when the freezer door is not closing properly / completely ... allowing air / moisture to enter the fridge/freezer . Have those checked out first.
Mar 03, 2014 | Angelo Brothers Westinghouse (r) Savona ES...
Doors won't stay closed!
Frost in the rear of freezer possibly caused by door staying open.  Door staying open possibly caused by frost buildup on ref door track.  Start by making sure the teeth on the freezer track are clear of ice and frost.  This should allow you to shut the freezer door.  Next check the freezer seal.  If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Oct 25, 2009 | LG (LRBC22522ST) Stainless Steel
Frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Jul 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Frost in frostfree freezer
Make sure your rubber seal around the inside lip of the freezer is clean and sealing properly! this can be the first cause of frost !
Dec 10, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Kenmore 57029 Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
