Question about Ryobi Backpack Blower 25.4cc
It won't rev up all the way. When I open the throttle all the way, it sounds like it's choking down.
  • 3 Answers
Sounds like it's not getting enough fuel or air, or carb needs adjusted. Carb might also need rebuilt or fuel filter in gas tank could be clogged - should be able to blow thru it - could be something small enough as the gas cap being clogged which cuts of the syphoning of the gas from it. Good Luck
Posted on Sep 02, 2010
My rev will not go down when i rev it
POSSIBLY (if present - happened to me on a different bike) a mechanical link between choke and throttle got stiff so 'choke' (the 'a bit more throttle' component) kept the revs up.
Jul 14, 2013 | kawasaki ZX-6R Ninja Motorcycles
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
1996 sportsman 400 wont idle. Had the carb cleaned by a "mechanic" after the bike took off wide open and driver was injured. He said the float stuck and he "fixed" the problem. Now...
I have NEVER heard of a float sticking and causing that issue. Sounds to me like the Electronic Throttle Control (ETC) on the right handlebar isn't or wasn't adjusted. There is a thumb nut on the throttle cable coming out of the ETC switch. Loosen the screw and turn the cable in or out to get 1/16 to 1/8 inch freeplay on the thumb throttle. Too loose and it won't idle, too tight and it will pull the throttle cable tight and rev engine. It could also be a carburetor issue if it runs with choke. Either the idle screw isn't adjusted or the pilot jet is plugged. There is a large thumb screw coming off the carburetor, turning clockwise will turn the idle up. Let me know if you need anything else, Daniel.
Sep 18, 2011 | Polaris ATV
Ok i just got a 2004 crf 70. i have taken carb apart twice and cleaned every jet ect... problem is when wide open it cuts out spits and spudders. I have changed settings on throttle cable and swapped out...
Could be that you need to go up one jet size.
When choking a motor, your richening the mixture with more fuel, less air.
So if you must choke it, you must need more fuel.
As for electrical. some bikes have a rev limiter when you hold the throttle wide open You may be reaching the rev limit.
A rev limiter with turn the power on/off the coil superfast, keeping the rmp at a maximum factory setting, and the motor breaks up at full throttle.
Some cdi's have and adjustment that you can set your own rev limit, or you can buy a cdi with no rev limit.
Hope this helps
Dec 09, 2010 | Honda CRF 100 F Motorcycles
1982 firebird trans am with the 5.0 V8. when started ti immediately goes to 7000 rpm. Looked at the throttle linkage and it appears to be free and working correctly. what else should I be looking for?
DOES ENGINE REV OR JUST TACH READS 7K?
IF JUST TACH READING THERE IS FIX ( RESISTOR)
IF REVS CHECK FLOOR MAT OR SECONDARY ON CARB. HUNG OPEN
Dec 08, 2010 | 1983 Pontiac Firebird
Poor idle
Throttle cable needs oiling ,Up for choke on .
Mar 20, 2010 | 2003 Suzuki DR-Z 125 L
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
START VEHICLE, IDLES AT ABOUT 600REVS, IF LEFT SITTING AT IDLE IT JUST GETS FASTER AND FASTER AND WILL REV TO 2000+ REVS CHECKED LINKAGES AND LUBED
Sounds like a engine warming up and the choke opening without being allow thh reset the linkage. When it does that, tap the throttle and see if it drops to proper idle. choke may need adjustment for standing warm up. good luck
May 17, 2009 | 1984 Toyota Land Cruiser
Ryobi Backpack Blower 25.4cc Logo
194 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
