Question about Garden
Replaced main drive belt on my wheel horse 211-5 speed tractor raised back end started engine put tranny in gear, speeded engine up and drive wheels would not rotate, belt tension is tight as i could get it this tractor calls for a 88inch belt I tightened it as good as I could still no rotation in any gear. thank you for your help.
SOURCE: John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
Posted on Sep 05, 2009
mowerman1857
  • 389 Answers
SOURCE: Concerning Husqvarna LR120 lawn tractor. Gears will not engae.
Recheck your installation. It sounds like you perhaps got the belt on the wrong side of one or more belt guides. If you need an owners manual, post your full model and serial number and I will see if I can locate one for you
Posted on Sep 25, 2009
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
  • 420 Answers
SOURCE: Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Posted on Jun 04, 2010
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
How do I find a wiring diagram manual?
well you might wanna check with TORO as they purchased wheel horse many years ago...
Sep 14, 2014 | Garden
Why doesnt my MTD 42" lawn tractor move but it will start?
If the transmission is belt drive, check the belt, worn/oily? If you have a hydrastat tranny, make sure that the bypass plunger is pushed in. Check that the belt goes around the tranny pulley. If still no luck, turn mower off, jack up and support the rear frame, with the real wheels hanging in the air(just an inch or two is plenty) try turning the wheels -1st, with the gear selector in "N". then 2nd, with the gear selector in "D". This should narrow the problem down a bad tranny or a sheared keyway in the axle.
Jun 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
I have a Noma model signature 1340, 12.5 HP riding tractor. i am not sure of the age. last time we used it to cut grass, it worked great. we parked it in the shed. went to use again and it starts and runs...
Hi, Just got your request and am now going to look up all I can find on this model of tractor. In the mean time double check your push or drive lever again to make sure it is not binding and make sure the blades are not selected, although I am sure they are not but at this point I am not ruling anything out. I will have to dig into this issue and check on the trans axle set up for you.
Oct 22, 2011 | John Deere Garden
My 2000 model mazda protege makes a clunk when making sharp turns, accelerating or shifting from 1st to 2nd gear?
Sounds like a bad cv joint. Easy way to check is to raise the front of the vehicle so both front tires are off the ground. Use jack stands under the vehicle and block the rear tires. Start the engine and put the tranny in drive. Let the front wheels rotate while the engine is idling and turn the steering wheel slowly in both directions. Listen for the clunking noise. You may have to speed the engine up a little to make it work.
Jan 12, 2011 | 2000 Mazda Protege
Jul 18, 2010 | Toro Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
MTD mower won't engage traction belts
Check to see if rear axle is broke. Jack up the rear of the tractor, put it in gear and spin one of the rear wheels, the one on the other side should spin the opposite way. hope this helps
Jul 13, 2009 | Garden
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
194 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
