Question about Sony Handycam DCR-DVD100E DVD Camcorder
I have a Sony Handican DVR-DVD100E. I need a battery. The camera is 7.4v 1300mAh. The battery has SQ Lithium M printed om the end and has 3 metal holes on the side.
    Problem Solver:
  • 6 Answers
Easy i found one on google search quick- co has one £1199 and £10 just type your cams number sony handycam dvr-dvd100e and bingo thers ten to fifteen shops that sell it google magic good luck.
Posted on Aug 04, 2010
Hello, I work for the Math department here at Portland Community College. Our little datemark is flashing p.reset and we don't know why. (My boss is downloading the manual but I am trying you). We put...
Please try the following:
  1. Remove all the batteries including the 3v lithium battery. In the 3v lithium battery compartment you will see a metal tab. Bend this metal tab upward slightly to ensure good contact with the lithium battery.
  2. With the batteries out, turn the unit over so you can see the print ribbon. At one end of the print ribbon you will see a plastic bracket. This plastic bracket should move freely. Using a pen or pencil point, gently move the plastic bracket from side to side in order to ensure it's able to move freely on the print ribbon.
  3. Check the display and make sure it is completely blank. Replace all of the batteries.
  4. Press the P-Reset button with a pen/pencil point or a straightened paper clip.
Hope this help, if it does please rate my help. Thanks
Nov 02, 2010 | Dymo DateMark Date/Time Stamper
Tip
Battery Basic Knowledge,Battery Voltage,Capacity
With the popularity of notebook computers, laptop battery was increasingly high, but you understand the notebook battery voltage, capacity, batteries What is the relationship between it? <br /> Here let us introduce you one by one. <br /> In the electrical, common voltage, battery capacity and other concepts to measure the properties and performance of the individual. General single dry cell batteries (including alkaline batteries) are rated at 1.5V, nickel-cadmium batteries and nickel-metal hydride batteries to 1.2V, while the lithium-ion battery is a 3.6V (some manufacturers of lithium-ion battery rated voltage calibration 3.7V) , the equivalent of three nickel-cadmium or nickel metal hydride batteries in series from the voltage, some common non-rechargeable lithium battery voltage is 3V. <br /> As a single battery voltage and capacity are very limited, generally need to form the battery pack with a few batteries to meet the needs of different devices, the actual power. In digital cameras, the most common battery combination is in series, that is, to the battery positive and negative end to end, such as the four 1.2V, 1300mAh battery in series to form a voltage is 4.8V, capacity 1300mAh battery pack; In the notebook computer, the battery is commonly used hybrid approach, that is, there are parallel series. <br /> Capacity refers to the size of the battery storage capacity. Battery capacity of the unit is the "mAh", Chinese name is mA (high-capacity battery to measure such as lead batteries, in order to convenience, general use "Ah" to represent the Chinese name is Ah, 1Ah = 1000mAh). Figure 4 in the GP super battery's rated capacity is 1300mAh, if 0.1C (C is battery capacity), or 130mA of current to the battery discharge, then the battery can last 10 hours (1300mAh/130mA = 10h); if discharge current of 1300mA, the only time that supply about 1 hour (the actual work time due to the battery's actual capacity of the individual differences and there are some differences.) This is the ideal state analysis, digital equipment, the actual work was not always possible when the current is constant at a value (in digital cameras, for example, because of the work of the current LCD display, flash and other components which occurs on or off the larger change), so the battery can power a device is about the value of the time only, and this value is only through practical experience to estimate. <br /> How to calculate that the number of batteries it? <br /> Calculate the number of batteries, depending on what your battery is batteries, generally have lithium with hydrogen power, marked with the LI-LON is lithium, lithium batteries for every energy-saving 3.6V, or 3.7V as the standard, <br /> HI-HM is hydrogen power, hydrogen power is 1.2V as standard. Ordinary hydrogen power, then the subject directly to the battery voltage divided by 1.2, that is, the number of batteries inside <br /> If the lithium battery, it would be in addition 3.6 or 3.7, which it wants to be divisible, such as 10.8V, it is to string together three of the core energy-saving, that at least three, and then look at the capacity, if the 4400's, that is Two energy-saving core parallel, each 2,200-capacity, which had six power-saving core, if 6600, that is, 9, and also the capacity of each section 2200, if 4000, that is six, indicating that low-capacity batteries inside that the capacity of each section in 2000 <br /> Peugeot general such battery, 10.8V, Capacity: 3600,3800,4000,4400,4600,4800,5200, these are the six sections, and greater capacity, indicating that the greater the capacity of each of the core energy-saving, but the batteries the same number, again: 10.8V, Capacity: 6000,6400,6600, these are nine sections, Some of 14.4V, the capacity of 4000,4400, which are eight, and this pushed down, your battery is the number of the batteries. <br /> <b>Professional battery shop ( sales-battery.com ):</b><br /> <b>( Buy now free shipping on orders over $ 87.99 )</b><br /> <br /> Laptop batteries: <br /> <a href="http://www.sales-battery.com/laptop-batteries.htm">http://www.sales-battery.com/laptop-batteries.htm</a><br /> <br /> Digital camera batteries:<br /> <a href="http://www.sales-battery.com/digital-camera-batteries.htm">http://www.sales-battery.com/digital-camera-batteries.htm</a><br /> <br /> Camcorder batteries: <br /> <a href="http://www.sales-battery.com/camcorder-batteries.htm">http://www.sales-battery.com/camcorder-batteries.htm</a>
on Dec 09, 2010 | Cameras
I want to put my videos onto my computer i have a disc dvd- rw which belongs to my sony viseo camera dvd100e everytime i try to open it in e drive it says my disc is corrupted and unreadable... how do i...
Sony Camcorders that record to DVD's require you to Finalise the DVD before you can use it on anything else.
If you have the Manual for your Camera look at the section which explains how to Finalise the DVD.
The finalise function is accessed via the Camera's setup menu.
Let me know how you get on. Regards,
Feb 10, 2010 | Sony Handycam DCR-DVD100E DVD Camcorder
I have CD recorded by Sony Handcam DCR-DVD100e; how can I download the movie to computer?
Extra.
Once you have downloaded the Manual, Finialising a Disc can be found on page 64.
Regards,
Jan 02, 2010 | Sony Handycam DCR-DVD100E DVD Camcorder
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Digital still camera
Hey rolvnetr,
The Sony Cyber-shot DSC-S700 Digital Camera should be powered by 2 AA batteries. There are 3 main varieties of AA batteries which are Alkaline, Lithium, and rechargeable NiMH batteries. I prefer Lithium batteries, but rechargeable batteries are also nice but once they start losing their charge it goes fast so have a backup set. You should be able to buy any of these batteries at most retailers, and of course our Best Buy™ stores carry these batteries.
Sincerely,
Allan
Go Ahead. Use Us.
May 03, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Maxxum 7000 camera lithium battery
The lithium button cell is under the metal plate where the battery holder attaches. There are six screws holding the plate to the camera. I believe the cell is a CR-2025.
That being said, replacing the lithium battery will only restore the cameras ability to remember your settings and frame counter when the regular batteries are not on the camera. It will not restore functions of the camera.
If the camera is not functioning properly, you have a power problem with the main batteries, not the memory backup cell
Mar 21, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Sony DSC-S650 ( 7.2 MP and 3x zoom) - Not working
I have the same camera and have had the same problem. The first time I had to change batteries I could not find lithium batteries and ended up trying alkaline batteries. I was only able to take 1 or 2 pictures before they would die and the camera would shut down. When I switched back to lithium batteries, everything worked fine. I hope this helps.
Dec 30, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Use of batteries in digital camera
you can change from nickel metal hylide to lithium ion batteries but you need a lithium charger. DO NOT SUBSTITUTE chargers! I've had my sony mavica for 7 years I have not needed to change the flashtube. the flashtube is a xenon based flashtube.
Nov 29, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Handycam DCR-DVD100E DVD Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
