Question about Canon imageRUNNER C3200 Copier
When I cahnge a new Black Drum, the copier keep turning off. Is there a special way of changing the Drum
  • 1,219 Answers
When copier is automatically turned off it usually means that you have fixing trouble.
Try to reinsert the fixing unit.
For service manual you can contact me on emma.servis@gmail.com
Posted on Aug 04, 2010
Ricoh aficio 1800 .why copies are now black lines appear from top to bottom?
I guess you talk about Ricoh MP 1800.
The Black lines on the bottom appear because the copier has made more than 60,000 prints or more if new.
If it's bought used, than it has made 60,000 or more prints from the last change of the drum and the drum cleaning blade. For the print to be clean again, it will need to be changed the drum and drum cleaning blade. This copier as all other copiers have parts that have a yield.
Aug 25, 2016 | Ricoh Aficio Office Equipment & Supplies
Got a ir2225 canon copier printing some white lines, anyone know why?
quite possibly you might need to do a head clean or a re-alignment of your printer.
Dec 12, 2014 | Canon Office Equipment & Supplies
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
My 5316 copier keeps blinking F2 and willnot print I have changed my developer still it keeps showing F2
F2 - Black toner supply trouble
Try a different toner cart, remember to shake the cart. before installing. Power the machine on and off and check. Check the sealing tape has been fully removed from the cartridge as well as the green colored plug.
Also, if you have an original drum unit frame, change the frame with the new Modified version to prevent arching at the rear cover of the drum unit against the inside back plate of the machine.
Check that the black dev. tank is not low or empty, re-position both drum & dev. tank.
Pls rate - Thank you
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code u28
It ask me to change the black drum unit. I changed a new one. But the error message is still over there.
If you have any suggestion, send E-MAIL to zwu@groupekwa.com
Thanks.
Oct 06, 2008 | Panasonic WORKiO DP-C262 Printer
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon imageRUNNER C3200 Copier Logo
26 people viewed this question
old marine
old marine
