Question about Campbell Hausfeld 26 - Gallon Air Compressor
The drive belt broken , looking for a new one for replacement. Model WL650001AJ . 5HP
  • 50 Answers
Go in 2 any autofactors wit old belt they should have 1 to match
Posted on Aug 03, 2010
Broken belt on Sunbeam bread machine Model 5891
I sell replacement belts. Visit me at breadmachineshelp.com and include the numbers & letters off of your old belt. The numbers will look something like this: STS 60 S3M471 OR STS 80 S3M 514 or you can just email me the belt code to my email address which is daryl441@msn.com
Feb 10, 2013 | Sunbeam Bread Maker, Large 2lb Model 5891,...
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
T30 model 242 Safety relief valve pops off at 50-60 lbs pressure. Put on a new one and still the same problem. Don't know what to look for next. Normal cut out is at 150-175. Thanks
From want you are describing sounds like the high pressure valves are leaking in the HP Head. there are 2 safeties on this unit . If the safety that's lifting is between the low and high pressure cylinders it's hp valves leaking. If the tank safety is lifting at 50-60 psi It should be replaced. It is a 200 psi safety.
May 26, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
Hitachi gdr-8161b dvd drive has broken drive belt. Is a replacement belt available?
Just replace the drive look on Ebay you can pick one up for under $20. It doesn't have to be the exact model desktop IDE drives are inner-changeable.
Jan 15, 2010 | Computers & Internet
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Autowrench model AAW100 belt is broken
Just replace the broken belt with an O Ring of comparable size, it works great and you can't tell the difference!
Nov 22, 2009 | Black & Decker AAW100 Automatic Adjustable...
Looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Apr 05, 2009 | Garden
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
235 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
