I have no assembly instruction for town house elysee 3 door wardrobe with mirror is there any were i can get them from on line
2 Suggested Answers
  • 122 Answers
SOURCE: Where can I find instruction manual for Capella 3 door 3 drawer wardrobe
check for manufactures name then send to them for manual or look up on inter net google it
Posted on Mar 16, 2015
How do I assemble a Stag Minstrel wardrobe from its component parts?
These are the instructions for a Stag Minstrel S150 double door wardrobe which I hope helps figuring out what goes where etc..
I've just noticed the photo isn't very clear on line, so here is a transcript of what it says.
Instructions for dismantling Stag Minstrel double wardrobe S150.
1. Remove shelf by sliding forward.
2. Remove hanging rods and shoe rail by sliding their end ferrules ( the circular bits the rods pass through) inwards and sliding the rods clear.
3. Remove the screws that pass through the lower wings of the top gussets into the end panel.
4. Close both doors, bolting the left hand door at the bottom only.
5. Remove the screws that pass through the carcase back into the top panel
6. Remove the screws which pass down through the top of the wardrobe into the end panels, and lift the top, complete with gussets and shelf supports, clear of the wardrobe.
7. Lay the wardrobe on its back, and remove the screws which pass upward through the front and back rails into the bottom panel.
Pull the plinth clear. The wardrobe will now divide into two halves.
NOTE : When reassembling the wardrobe make sure that
(a) the two halves of the wardrobe are located correctly together before fitting the plinth over the bottom location blocks ;
(b) all screws enter the holes bored for them.
Jun 13, 2015 | Home
Replace the review mirror
You need to remove the plastic plate that cover the mirror joint from the inside and undo the three bolts.
Oct 30, 2008 | 2006 Chrysler Town & Country
I need assembly instructions for my Powell Cheval jewelry wardrobe
I have know the wardrobe design services company.They will guide the Correct instructions about jewellery wardrobes.Site address of wardrobe design firm Robetek Industries http://robetek.com.au/ .
Feb 13, 2015 | Powell Company Walnut" Cheval Jewelry...
Need to replace drivers side mirror assembly, could use a diagram or instructions.
there is probably a small cover on the 'back' part of the mmirror housing, by the corner front part of the window/door=pry it back, it will expose small bolts/screws that hold the housing to the door.
Dec 23, 2010 | 2006 Toyota Corolla
Replacing a brokem mirror on a 1996 chrysler town
directly behind the mirror on the inside of the door there will be a plastic triangular shaped cover
gently remove the cover using your fingers or something flat like a knife blade
once removed you will see a few holes in the metal of the door, in these holes you will see about 3 bolt heads which hold the mirror to the door, also you will see a multi wire block for the mirror wiring
seperate the wiring block and remove the 3 bolts holding the mirror to the door
don't even think about replacing the glass if that is all that is broken as it is a major drama
just buy a complete mirror assembly and fit to the door unless it is colour coded to the paint on the car in which case you will have to have it painted
re assemble in reverse order to disassembly
hope this helps
Jul 02, 2010 | 2006 Chrysler Town & Country
Looking to replace passenger side mirror on a 2006 Town and Country. Anyone have Instructions available?
    Remove Old Mirror
  1. 1 Open the side door to the Chrysler Town & Country, and find thescrew that holds the side mirror molding in place.
  2. Take the screw out and remove the molding panel that attached around the outside of the power mirror.
  3. Remove the bolts connecting the mirror to the door assembly. If equipped, unplug the power side view mirror wiring harness connector.
  4. Unplug the electric connectors, and pull the mirror out of the molding.
Jun 01, 2010 | 2006 Chrysler Town & Country
How do i replace left door mirior
remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
Removal and Installation
  1. Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
  1. Using a small flat-bladed screw driver or equivalent, move latch release to released position.
  1. Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
  1. Disconnect heater wire connectors and auto dimmer connector, if equipped.
  1. To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door Front—Town Car
Removal
  1. Snap out two door pull strap retaining screw covers. Remove screws.
  1. Remove three screws on front and rear side and center of front door trim panel (23942).
  1. NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
    Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
  1. NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
    Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
  1. Disconnect wiring harness and heated seat switch electrical connectors if equipped.
  1. Remove the door trim panel.
  1. Disconnect two electrical connectors.
  1. Remove nut from outside rear view mirror mounting base.
  1. Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
  1. Remove screw from outside rear view mirror base.
  1. Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
  1. To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
Nov 05, 2009 | 1996 Lincoln Town Car
Hot to install driver's side rearview mirror '98 Expedition
3 10mm nuts located behind the interior door panel (directly behind the mirror assembly) attach the mirror to the door. Also there you will find the point of attachment for the power as well.
Oct 01, 2009 | 1998 Ford Expedition
Pontiac Montana
You'll have to replace the entire assembly if you're missing the mounting piece that the mirrors sit on inside the housing... You'll need to remove the door panel in order to remove the panel that's right beside the mirror on the inside of the door and remove the 3 bolts holding the mirror down assembly down....
Aug 11, 2009 | 2003 Pontiac Montana
Open Questions:
The smartest way to keep your business files secured on online cloud backup The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Aug 18, 2018 | The Computers & Internet
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
