Question about Panasonic DVD-LS86 Portable DVD Player
Wont power up with battery or A/C plug - Panasonic DVD-LS86 Portable DVD Player
My toshiba CB35-A3120 chromebook just turned off,and now won't power back on.Tried a extra power adapter,nothing.
remove your battery and power from it for half an hour then plug just the chromebook power cord back in and see if it turns on without the battery in. if it does then unplug put battery in then plug power back in and try to turn it on again if it doesn't come up with the battery plugged in with the power plugged in you may need a new battery. the chromebook should run good without the battery but you wont be able to use it when you have no power around.
Mar 18, 2015 | Toshiba Computers & Internet
Why my htc explorer wont stop vibrating and cant power on.
your phone have hardware problem so go to the service station to resolve
May 16, 2017 | HTC Explorer A310e Black Android 2.3...
Why my htc explorer wont stop vibrating and cant power on?
dude its a serious problem...let it checked by any harware expert..we can only solve your s/w related problem not h/w...So go to a reparing shop.
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
Battery wont charge and wont work off power supply vaio vgn cr35g ?
i know they are not cheap but it sounds like you need a new battery. is there a light on your charger? is it still on and the same color?
Mar 20, 2013 | Sony VAIO Computers & Internet
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
Mp95 wont turn on. The battery pack wont charge and player also wont turn on while power source is hooked directly up to dvd player without battery pack. Please help?!?!
The battery it is dead,even u plug the dvd player power in directly into the power source.Must have the battery inside and the must have some juiced left before for the dvd player to work.Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new battery or a compatible one.
May 09, 2011 | Mustek MP95 Portable DVD Player
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
My pv-gs180 camcorder wont power up. I have
Remove battery plug it into power (charger block) then do reset.
Oct 12, 2009 | Panasonic PV-GS180 Mini DV Digital...
Laptop wont power up?
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 03, 2009 | Computers & Internet
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Panasonic DVD-LS86 Portable DVD Player Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
