Question about Biostar P4M80-M7 Motherboard
I want to know how bios work - Biostar P4M80-M7 Motherboard
Reset bios password on toshiba satellite l875d - s7332
Heres a good bios password cracker than works guys! and its cheap!
http://www.bios-passcrack.org
06/16/2015 by Benjamin NIchols download original backup bios file laptops
Download EC & Bios files...
Bin , Hex , Rom
Contact Us: http://dr-bios.com/
10/01/2015 by Salimeh
Feb 01, 2017 | Toshiba Computers & Internet
I found out my VGN-AR870 supports hardware virtualization, but the current BIOS does not. Is there a BIOS upgrade that will work?
if there is it will be on sony's website. i know after hardware virtualization came big into play alot of makers of bios's (pheonix ami etc) scrambled to release bios updates. check sonys website for the newest bios and how to flash your bios. let me know if this helps
Mar 19, 2011 | Sony VAIO VGNAR870 Series Laptop Charger...
How to bypass bios password on a Toshiba Satellite 1305-s6858
the bios password is a tough one,
once i took out the bios password component, and it worked , but very small solder joints there
Apr 03, 2010 | Toshiba Satellite PSAG0U-02D00M Notebook
Help
I found a bios up date.
You need to choose which operating system your are using.
here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=228&product=3436820&
It looks like they don't offer an update if your OS is XP but the newer OS's show a bios update.
let me know if this works
Feb 19, 2010 | HP Compaq Presario SR5130NX PC Desktop
How to restore my bios on a desktop.
Remove the "button" battery on the motherboard and turn the computer on.
Shut down and put battery back in.
or ... there are two (or 3) pins next to the BIOS chip that may be marked reset / normal.
Either temporarily short the two pins and release (done)
or ... move the jumper from one side of the set to the other side of the set (pin 1 & 2 .. move jumper to 2 & 3) and then back to the original position (done)
Sep 21, 2009 | Computers & Internet
Bios damaged
You are fortunate that your BIOS has a built-in recovery procedure. However, you will need a working floppy drive to recover the damaged BIOS.
Do you know what BIOS microcode you're using? Specifically, do you have an Award, AMI, or Phoenix BIOS? (Or some other one?)
Award, AMI, and Phoenix all have different procedures for recovering the BIOS. Once you know which one you have, search Google for "XXXX BIOS recovery" (Where XXXX is Award, AMI, or Phoenix).
Typically, the procedure includes placing a BIOS file onto a floppy, renaming it to a specific name (like AMIBOOT.ROM) and inserting that floppy into the drive.
Jul 19, 2009 | Computers & Internet
Acer travelmate 4000 hardisk problem
If the hard drive doesn't show up in BIOS either the drive is new to the unit, drive has failed or the motherboard may have a failed IDE/SATA.
If it's a new drive you're trying, go into bios and disable Fast/Quick Post/Boot from bios and restart the computer it should find it. If not either try a new drive you know works in the laptop or your drive in a laptop you know works and we'll figure it out from there.
Try these steps and let me know how it works out, if you can't get it narrowed down I'll offer a few more suggestions.
Chris
May 24, 2009 | IBM Computers & Internet
I have dell inspiron 1525 model and it not working in its actual bios setting but it start to work , when i make some change in bios setting and i want to know that how my system should work in its actual...
Best thing to do is to just reset the BIOS Defaults. This will make sure that your BIOS is setup just like it was from the factory. This also will help cause if your having other hardware problems you know that its something inside of the laptop instead of a setting in the BIOS.
Apr 20, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
BIOS help
Hello
you need to download right bios and burn it to a CD, then you need to boot from that cd.
plz give me the exactly model of your computer? and I will search for the bios update.
you can boot from the recovery cds before you have "installed" the right bios.
let me know the exact model and I will give you more instructions what todo.
if you know how to burn and how to get the right bios go here and input your model.
else let me know.
hp drivers
Oct 09, 2008 | HP Pavilion dv9000z Notebook
Bios
Are you trying with "F11" Key ?
some deskpro models do have bios disk just check with F11 if its not working will try to find starter floppy drive to enter BIOS
Dec 21, 2007 | Compaq Deskpro 2000 PC Desktop
Biostar P4M80-M7 Motherboard Logo
20 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
