Question about True GDM-33-SSL-54 Refrigerator
There is snow on the coil at the top, unit only cools to 48*. I have defrosted the unit and reset the dial to 1 as recommended in manual. Still hearing the clanging of either water or snow/ice hitting the fan. the drain pan underneath the unit is empty and dry. I can not tell if the drain line is clogged .
  • 755 Answers
The drain line is mostly likely clogged.
You need to find the drain line and try snaking the line out with either compressed air or a fairly sturdy length of wire.
Taking the face of the evaporator fan off would probably help with finding the drain. Unplug the fridge while doing this so you arent working around live fans or the defroster!
Good luck and be careful.
Posted on Aug 03, 2010
Superba 48 stopped completely
Hello Shawn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number. The model number is on a label, on the liner inside wall of your fresh food section near the top.
I picked a Superba 48 model number at random to see what you have. The model I picked - the control boards are not available. But these are not your problem.
Every 8-10 hours your unit completely shuts down except for the lights, and goes into a defrost mode. This is where your defrost heater turns on for 20-30 minutes, defrost your cooling (Evaporator) coil, and then turns your unit back on. You may have a bad defrost timer.
1.) Defrost Timer - Behind your unit is a defrost timer.
The timer is mounted on the back a steel bracket with a hole through it. Take a flat head screw driver, turn the round shaft one click at a time clockwise until the unit turns on and is running.
If the unit turns on, then you have a bad defrost timer.
Note: When replacing note what contact number the black wire is connect.
2.) Power On/Off Switch - In the lower back, you also have a Power On/Off switch. Unplug the unit disconnect the 2 wire leads on the switch. Using a multi-meter, set ant the lowest Ohms (Omega Symbol), Ohm out the switch. If you get a reading other that '0', then the switch is bad.
Dec 28, 2014 | Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
Ge profile PSS26MGP side by side installed in Oct 2008. Background: on 1-03-2011 freeze-refer temps approx 13 and 48, apples in top deli-fresh drawer were frozen. Ice maker not making ice, minimal water...
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a Side x Side style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing,or an inefficient not 100% pumping compressor.
Feb 07, 2011 | Refrigerators
GE Model TBX18JISERWH This refrigerator is a freezer on top/refr on bottom.....the problem is that the freezer section is working fine,but the refrig isn't cooling enough. The temo gets up to 48/49...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice or is cold . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 29, 2010 | Refrigerators
My Amana ABB2524HEW quit defrosting. I have manually defrosted the unit and unit is cooling fine. I can manually defrost ok with the digital control. I did Service Test 1 and the defrost thermostat showed...
Good day,
If the machine has been running at least 6 hours in cooling mode, and the thermostat shows open. It is defective, and needs replaced.
It is located in the freezer section behind the back panel, and is located on the top of the cooling coil.
Hope that helps.
Thanks for using FixYa
Jan 25, 2010 | Refrigerators
ET21DMXDW04 TOP-FREEZER REFRIDGERATOR The fan
The evaporator fan should run all the time that the unit is out of defrost. The only time this fan is off is when the unit is in defrost.There are two pssibilities for the "snow", it is either the defrost timer or the defrost termination control. Change the defrost timer first, on 90% this is the problem. If not change the defrost termination control located on the refrigerant line leaving the evaporator coil.
Oct 31, 2009 | Whirlpool Refrigerators
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Temp control on high food not freezing
Look for snowy frost build up on the inside rear freezer panel. If there is snow, your self defrost system is not working. 90% chance your defrost heaters are burned out (will sow open with multimeter set for continuity, Rx10, Rx100, etc...) If the heater is good check the defrost termination thermostat at the top of the evaporator (cooling coil) it is clipped to the top. About the size of 15 quarters stacked up.. two wires coming out of it. It will only show closed if it is below around 20 degrees. If neither of them is bad, replace the defrost timer. It is in the top of the fresh food section by the control dials.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Sub zero side by side
IT MIGHT HAVE A DEFROST PROBLEM IF IT HAS A SNOW BUILD UP ON THE BACK PANEL IN THE FREEZOR THEN IT DOES CHECK DEFROST TIMER IF IT IS A CAM DRIVEN TIMER U CAN MANUALY TURN IT INTO DEFROST CHAECK TO SEE IF DEFROST HEATER COMES ON IF IT DOES BUY ANEW DEFROST TIMER
Aug 25, 2007 | Sub-Zero 690 Side by Side Refrigerator
True GDM-33-SSL-54 Refrigerator Logo
79 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
