Question about Primavera SureTrak Project Manager 3.0 for PC
Suretrak 3.0b: When I go to page setup on some projects and change the parameters and click ok I get an error message ?Invalid path or filename?. It will not let me change anything in page setup. I have tried saving as a smaller file name in a different location; shut down Suretrak and reopened the newly saved file to no avail. Your help will be greatly appreciated
When I had this issue it was fixed by removing any references to a logo that was not valid anymore. Go to Page Setup-Footer and if any of the Footer Blocks reference a Logo you can either click on each one, which will bring up a Flie Path selection box, or remove any logos by hitting the down arrow and changing from Logo to none.
Posted on Jan 10, 2011
Suretrak 3.0b: invalid path or file name when I try to save file as something else
The error message about invalid path is referring to a missing logo file. In the footer, or header, set Logo to None, or find the missing .bmp file and place it in your default SureTrak Clipart folder and re-browse to its location.
Aug 04, 2014 | Primavera SureTrak Project Manager 3.0 for...
How do i fix an invalid path or filename error when saving
I answered this once, but it didn't seem to post. Invalid Path or Filename error is generated when a logo (.bmp) file is specified in the header or footer, but is not found in the default folder "Clipart," usually found under SureTrak in Program Files or Program Files(x86). Either set the logo in the footer to None, or copy and paste the missing .bmp file to the Clipart folder, then in the Footer (Page Setup, third tab) re-browse the logo setting to the correct location.
May 21, 2014 | Primavera SureTrak Project Manager 3.0 for...
When I wanted to delete a file It gives an error message "Cannot delete nul: The parameter is incorrect"
Right click the file, Security, advanced, owner. Change the ower to the user you are using to delete the file. Apply and OK, to complete the taking owership of the file.
Delete the file.
Mar 11, 2011 | Computers & Internet
After clicking print to PDF a schedule, Suretrak shows error message that says Suretrak Application Manager has encountered an error and needs to close. No other info.
I would try reinstalling the software. Sounds like a file got corrupted. If that does not fix it:
Have installed the latest patches for SureTrack?
Have you updated Windows?
If so, did the problem start after one of the updates?
Mar 11, 2010 | Primavera SureTrak Project Manager 3.0 for...
I get invalid number of parameters with my .bat file
Hello Dear,
You need to get the absolute path in proper order to make it work with xcopy.
The $ sign with drive is meant for to hide it and make it available only for system specific use.
Thanks
Jan 25, 2010 | Microsoft Windows XP Professional SP2
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
Printing problems
Had a similar problem with printing from a file saved on a network drive. Apparently the file name was too long. Moving a copy of the file to the local drive (such as a folder on the desktop) allowed printing. I believe I am also functioning without the Suretrak 3.0a or 3.0b software patches which may correct the problem (see Primavera's website for patch b). Since it is only on certain files, I would think it is due to too long of a path to the filename.
Oct 06, 2008 | Primavera SureTrak Project Manager 3.0 for...
Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Open Questions:
See all Primavera SureTrak Project Manager 3.0 for PC Questions
Primavera SureTrak Project Manager 3.0 for PC Logo
727 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
john smith
Marvin
Marvin
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
