Question about Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range
Hi I have a Lofra MXG96MFI/C I have had it about 6 yrs bith top and bottom elements have broken, I cant find the model, is it the same as a newer model or could I still get elements for my exact 1?
4 Suggested Answers
  • 4 Answers
SOURCE: Can't find parts for Lofra range cooker
hi mark have you tried this service?
http://www.elementreplacement.co.uk/made-to-measure-ovencooker-elements-144-c.asp
Posted on Nov 18, 2009
SOURCE: Broken oven element
All sorted now. Found a company in Liverpool, very helpful. Posted replacement today.
Posted on Feb 02, 2010
SOURCE: I need a new ovn heat element in the bottom of a
Hi Kapshaug, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Posted on Jan 20, 2011
Inherited a LOFRA oven. Beneath the bottom element are two thick layers of insulation wrapped in foil. Above this element, enamelled tray also wrapped in foil. Can someone please explain? Is there a design...
Hi Virginia,
It looks like you inherited a good oven.
There is no substantial difference between a LOFRA oven and others on the market. Often foil is used to protect the surfaces so cleaning is made easy. I cannot understand why there is insulation in the oven. Does it appear as if the manufacturer has installed the insulation, or has it been placed there by its previous owner? This may have been placed in there to retain heat in the bottom of the oven.
I suggest that you check that the foil is not in contact or could come into contact with the element of the oven for safety.
Feb 03, 2014 | Ovens
We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
Hi Gina,
From what you are describing, it seems there was an "arc" from where the element itself was supposed to connected to the power in the bottom portion of the stove.
This may have caused the connector itself to burn, seal, or carbonize I.E. Blacken and not allow the element to properly connect to the internal workings.
The other possibility, because the broil is still working is that this particular model of a stove has multiple fuses for controlling the different elements in the oven portion.
You would need to consult the manual, likely available online via model number. The ranges themselves rarley change the electronics inside and if you cannot find the exact model number maybe a newer model 3 year newer would help.
The first thing to check is going to be the fuses themselves. If you have a multimeter available to check the current in the fuses.
If indeed it is the connectors where the element "clips" in to the base of the oven that has gone out, the work to replace it might be more tedious to accomplish.
If you find it is not the fuses, you can consult a repair guy, but likely, parts and labor will be more expensive than replacing the range itself.
Jan 08, 2014 | Kitchen Ranges
I need a new ovn heat element in the bottom of a Lofra 120 cm ovn type (later) which is burnt off and need to be replaced. I think is aproxamaterly on 1100 w element and have more details after a replay of...
Kind regards,
Lofra Sud America
Jan 17, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Max 160 degrees celcius
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Broken oven element
Feb 01, 2010 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
do you have a clue where i can grip some knobs for lofra gas cooker.
MXUD66GGI. i have tried every where can you help me.thanxs.
Jul 15, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Lofra cooker turns itself off
Hi looked on the wed could not find anyone only lofra try try them, hope this helps
Mar 12, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range Logo
121 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
