Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
I have 3 computers connected by router. All 3 have been using the hp 6310 all in one printer for a long time. Now all of a sudden when we try to print is says printer is off line. I have tried turning it off and disconnecting power source and USB cable and then turning everything back on again and reconnecting USB cable but still says offline. I would reinstall but can't find it in list to uninstall first.
  • 33 Answers
Hi! you can try this. rightclick to open all active printers in right downcorner there click the printer section and remove the x mark in use the printer in offline. you can allso check that your default printer is right not example the hpxxxxxxx (copy 1)
Posted on May 29, 2011
I have an HP 6313 all-in-one inkjet printer/scanner/fax. At some point the driver was updated and the new version of the software does not find the scanner. I have reinstalled the software a few times...
hello
the router is irrelevent in this maytter -- its an issue with your computer and the All In One printer.
(1) did you make sure you have the correct driver for the operating system ? for instance Vista has two drivers (32 bit and 64 bit)
(2) if so, reinstall the original drivers first for the printer
(3) after installing the original drivers and applications, go to the HP setup of this software to get new driver (through the printer software, not anything else). i hope it helps
if it still does not work let me know
Nov 02, 2010 | HP Officejet 6310 All-In-One InkJet...
Won't scan through network
You need to make sure that does it print or not. If it is printer then you need to disconnected printer HP 6310 printer and uninstall hp software using printer installation disk after that reboot your computer and reinstall completed printer software.
Thnx
Sachidanand
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing wirelessly using ethernet from printer to router.
You need to get IP address from the printer, and enter it in the router. Or sometimes the software will do it on installation
Apr 24, 2009 | HP OfficeJet 6310 All-in-One Printer...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
35 people viewed this question
Seeker5211
Seeker5211
