Question about Audio Technica Audio-Technica AT2020 - Condenser Microphone AT2020 Microphone
I have the Audio-Technica AT2020 USB microphone. I've been using it for about a week now. Today I went to use it, and all of a sudden my computer stopped recognizing it. When I plug it in, I get a bubble saying, "USB Device Not Recognized" What can I do to get my mic working again?
  • 532 Answers
Hi
Put it in another usb because the laptop as more than a port.
If that does not work use it on another laptop. Let me get the response.
Thanks.
Posted on Aug 04, 2010
  • silverman42
    silverman42 Jan 12, 2012
    i have the same problem and it does'n work on any other port of computer
  • silverman42
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
When i recored my vocals they are delayed so it goes over the beat instead of being on top of it and right on point
This is a common problem with recording multi-track sounds on a computer. It is caused by something that is known as 'latency' - basically it is down to the fact that the signal from your microphone takes a different route through the system to that taken by the audio playback. The AT2020 is a USB microphone and the signal therefore has to pass through the USB bus circuit of your computer. Despite claims of multi-tasking your computer cannot do everything at once so it naturally creates delays to make itself work properly. This will be more of a problem with a computer which has a 'cut-down' processor such as a Celeron (Intel) or Duron/Sempron (AMD). These processors are really only intended for basic computing (office type) use and are not really up to the high demands of video or audio recordings.
You may get some improvement by tweaking some of the audio settings for your sound-card to change the hardware acceleration.
This article may help you http://www.pcmus.com/latency.htm
If you are using a dedicated midi /music recording program such as Cubase then you may be able to correct the time lag using the 'quantise' function after recording your vocals. However the best solution is likely to be a hardware one Either buy a proper multi-track mixer/recorder designed for the purpose or get a second USB microphone - play your backing track on an external device - using one microphone to capture your voice and one to re-record the backing track (the only downside for this second option will be a gradual degrading of the sound quality each time it is re-cycled)
I plug my mic into my mac and try and use Garage Band. The playback has a bunch of static noise no matter how high the volume of my mic is. How do I fix this problem? My email is ty_smith22@hotmail.com
The standard ports on a mac are not the best for audio production. their impedance are quite low an I have found lots of recordings to come out clipped or like you say, full of noise.
Best think to do is to get a cheap USB 2 or firewire external soundcard. One of the best moves to bring a mac to audio life.
M-audio make a good range from ok price to quite pricey :-)
Jan 07, 2011 | Audio Technica Audio-Technica AT2020 -...
I dropped the audio technica at2020 mic and when i record it doesn't pick anything
Most likely it could be two things either a connection is not getting current anymore. my 2020s have went through hell and no problems. or the other suggestion is that your phantom power is not being sent from your preamp to the microphone (not to make you feel stupid, just a reoccuring problem on this board.)
Good Luck, Cody J.
Dec 17, 2010 | Audio Technica Audio-Technica AT2020 -...
My computer won't pick up my microphone. what do i do?
Might have to have windows find it and/or or use the windows disc if it asks for it! Might have to consult
a good "PC" shop/store!
Apr 15, 2010 | Audio Technica Audio-Technica AT2020...
What drivers can i download to make my at2020 usb work with windows vista
i hav just bought a at2020 mic and i tried recording bought it's not workin for my dell inspiron i forgot the model anyway it's running on windows 7 so please help me out am screwed with this ****
Mar 13, 2010 | Audio Technica Audio-Technica AT2020 -...
Audio-Technica AT2020 low audio output
Pins 2&3 are the correct ones to use for checking the voice coil. Pin 1 is chassis ground and should always read infinite resistance to the other two.
That microphone has an impedance of 100 ohms, so if you are reading 30 ohms you clearly have a problem with the voice coil.
Good Luck
BB
May 16, 2009 | Audio Technica Audio-Technica AT2020...
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Feb 21, 2009 | Audio Technica Audio-Technica AT2020 -...
829 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
