Question about LG LU20 Tablet PC
Rj45 socket repair - LG LU20 Tablet PC
    President:
  • 2,571 Answers
Your laptop has a card slot, it will take a pcmcia expansion card.
It may be cheaper to buy an ethernet card with a rj45 port, rather than trying to repair the laptops built in port.
I found some from about £10
http://www.amazon.co.uk/PCMCIA-RJ45-Ethernet-Networking-Expansion/dp/B000Q8FO70/ref=sr_1_2?ie=UTF8&s=electronics&qid=1280865787&sr=8-2
Posted on Aug 03, 2010
Testimonial: "thank you very much for your fast reply it was very helpful "
Galaxy tab 2 charger/usb socket faulty
I paid GBP £25 for a socket replacement such as this.
Took it to a local phone etc. repair shop.
Jul 19, 2016 | Samsung Galaxy Tab 2
How do I get the back off.
Google it. There are u-tube videos dedicated to this type of thing/ better than any answer you'll get here. Don't forget MODEL & SERIAL number if possible!
Apr 06, 2015 | Tablets & eReaders
No power when plugged in? What did I do?
If you have a volt-ohm meter check that you have voltage at the plug to the computer. If no voltage, the power supply is bad or the socket does not have power (circuit breaker) change to a known working 120vac socket. Dobble check your laptop's power supply. If still bad, see if you can barrow one, or take laptop to repair shop and ask them to try their power supply. Then you will know to purchase a replacement.
Mar 31, 2015 | ASUS R1E-B1 Tablet PC
Proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
I have a problem with one of the the charging plug ins
The socket will need replacing. A computer repair shop will do it. Is there a standard round pin charger socket?? If so you'll need to purchase a charger for it
May 30, 2013 | ZEEPAD Tablets & eReaders
Charging socket broken
So its a time traveling device also? ;)
I assume you mean Dec. of 2012. It should have a 1 year manufacture warranty on it. I would call Toys R Us customer care and have them warranty it for you. 1-800-ToysRUs
May 23, 2013 | Toys R Us Tabeo
How to connect a RJ45 lan to tablet
if there is an usb port on it, you can connect it through a Ethernet USB adapter that will allow you to get online.
Jan 04, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
My laptop will not charge. If I hold the connection at the computer, and jiggle the transformer portion of the charger cord, it will charge briefly, but not continously. I have unplugged and replugged the...
When you plug in the adapter and wriggle the power plug and the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. You can DIY but if not confident to tackle it yourself then, I suggest you get a quote for the repair first.
Nov 26, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
LG LU20 Tablet PC Logo
334 people viewed this question
Top LG Tablets & eReaders Experts
Jax Planet
Jax Planet
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
