Question about Creative Labs Zen Touch MP3 Player
My creative zen touch will not dock
I have a creative zen touch which works for playing music etc. When i plug in the usb to download other music it just switches the zen on and doesnt dock. is it because i have updated my windows media to 10 or 11. im using windows xp. any suggestions please.
  • Anonymous Apr 29, 2008
    I PLUG THE ZEN IN DOWNLOAD LINEWIRE, BUT CAN'T FING THE USB DEVICE TO TRANSFER MUSIC. I HATE THIS THING
I had the same problem. This may help.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}http://support.creative.com/kb/ShowArticle.aspx?sid=16737
Posted on Apr 21, 2009
  • Yamabushi Apr 21, 2009
    This may help.
    http://support.creative.com/kb/ShowArtic...
Instruction for zen mosaic by creative
I think alot of people are having the same problem I was. We got home, opened the box, plugged it in the computer, and nothing useful happened so then we installed the mini-cd. Well the thing is windows stops looking for a driver once it searches and finds nothing, and unfortunately those of us using XP do not automatically have the drivers. So...
SOLUTION
-If you have not already installed the mini-cd, do so, or download from Creative's site in the support section(if you do you might want to grab the latest firmware update)
-Once pack has been installed the drivers have been as well, BUT as I mentioned we now have to tell windows to look for them again.
-Reconnect your Mosaic
-Right click "My Computer"
-Chose "Properties"
-Click the "Hardware" tab
-Click "Device Manager"
-A window will pop up and you will see a long list with (hopefully only) one thing under the "Other Devices" sublist. It should be something along the lines of "Creative Zen Mosaic". Right click it
-Chose "Update Drivers"
-Follow prompts agreeing to search and auto install
-Once install is done, in a moment the screen on your Mosaic will say "Docked"
-Congratulations!
If you have downloaded the updated firmware this is the time to install:
-Ensure your Mosaic is in "Docked" mode
-Execute the firmware update
-Click "Upgrade"
-Wait (it takes a moment or two)
-Updater will say it is complete
-Mosaic will reboot
-Click "Close"
-Congratulations!
Hope that helps.
Dec 11, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
Feb 20, 2008 | Creative Labs Zen Touch MP3 Player
Zen won't recognize songs, won't sync on computer
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Jan 24, 2008 | Creative Labs ZEN SLEEK MP3 Player
Docked prooblem
Plug it in and start charging it. Once it has a decent charge if you ever have that problem again... (see below)
Using the instructions below try Reset, first, if that doesn't fix it try the Cleanup method, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Jan 07, 2008 | Creative Labs Zen V MP3 Player
My Creative Zen M won't "dock"
One problem may be that the registry entry for the player is corrupted. You can find out if this is the case by opening your computer's Device Manager (this page tells how, if you're not familiar with it). Look under "Windows Portable Devices" if you have XP or "Portable Devices" if you have Vista, and you should see the name of your MP3 player.
If your player is listed in the Device Manager but has a small yellow warning sign next to it, right click on your player's name and click Properties. The Properties box may say "Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)."
If this is the case, there's an easy fix, that doesn't require any messing with the registry or anything:
--Right click on your player in the Device Manager and click Uninstall
--Unplug your player from your computer when the uninstall finishes
--Plug your player back in to your computer
--Vista will automatically reinstall the driver, and your player should appear in My Computer
Unfortunately this is for Vista. I don't believe XP will reinstall the driver automatically, so you may have to install it manually from your Creative CD. Anyway, what this does is simply uninstall the corrupt driver and reinstall it. It worked for me - hopefully it helps you!
Mar 22, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Touch Controls
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Feb 16, 2007 | Creative Labs Zen Touch MP3 Player
Says it's not docked, but it it is
Is your hardrive ok chceck it by listening to it and if you hear a clicking sound then its stuffed. Try reinstalling the CD that came with it and then reload the firware it soud work.
Jun 15, 2006 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen Touch MP3 Player Logo
391 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
