Question about Frigidaire Affinity ATF7000E Front Load Washer
When I turn on my Frigidaire Affinity washer, ERR flashes and beeps three times then it appears like it will work. However, if I push start, the temperature control simply changes and it will not start. Any ideas?
I have the same problem and i was curious if you have found a solution.
Thanks
Posted on Aug 20, 2011
Affinity dryer will not start beeps three times
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 29, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidadarie washer stopping and beeping three times
Does it flash any lights? What cycle did it stop in or begin having problems in? Make sure to hard reset the unit at the circuit breaker of your home for about 10 minutes then retry.
Aug 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer Logo
219 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
