Question about Health & Beauty
MY SHOP RIDER JERKS WHILE I AM MOVING,TOOK OUT BRUSH ON SIDE OF MOTOR LOOKS FINE.I THEN TOOK PART OFF END OF MOTOR HELD BY THREE SCREWS,THEN UNDONE TWO LONG SCREWS PULLED MAGNETISED MOTOR APART,CLEANED IT.WHEN I PUT MOTOR BACK TOGETHER THE RIGHT LEVER NOW GOES BACKWARDS VERY FAST,AND WHEN I PRESS THE LEFT LEVER IT NOW GOES FORWARD WHICH USED TO BE REVERSE BUT VERY SLOW.CAN YOU HELP ME PLEASE I HAVE NOT TAKEN ANY WIRES APART.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hello,please rate me for info with thumbs up 1 to 4.im disabled myself & i do this cause i care not for money.Please dont do anything else,you said you checked 1 brush.there are 2 & they should be a certain length plus,should slide in & out easy with the aid of the spring in each 1.there is a set out proceedure when searching for faultsWhat you need is to visit :www.alldatasheet.com. Type in -troubleshooter_2007 SHOPRIDER.pdf .You need to download this to be read in Adobe Reader as a PDF File you can save it on Adobe Reader & or print for future Ref.MAYBE PUT IT IN A POLYTHENE SLEVE FOLDER.tHAT WILL TELL YA ALL YOU WANNA KNOW.Or type in shoprider.com & b4 actually going into it ur search engine will give ya a load of links to click on look for the:PDF File in Adobe Reader.take care & b4 i forget,heres a tip anything you take on to repair,please for you take a pic with a mobile so you know exactly what was where,Colin.
Posted on Aug 05, 2010
Testimonial: "thank you for being so help full,and caring it is nice to know there are people like you willing to help disable people"
Carbon brush location
Looking at your manual pdf, it appears that your machine has an internal motor. On the end of the machine with the hand wheel there are a few screws that removes a panel. Remove that and you should be able to access the motor area. The brushes are typically riding in a port and held in place with 2 screw in type caps and a spring. One on top and one on bottom (though that can by side to side too.) remove the caps and catch the spring and brush as it comes out.
Hope that helps. Here is the PDF in case you need it.
http://www.singerco.com/uploads/download/648_328.pdf
Make sure you unplug your machine before accessing anything.
Aug 23, 2012 | Singer Sewing Machines
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My Model K5SS was making a squealing sound when mixing. I unscrewed the black screws on the sides to check the lubricant but when I replaced them the mixer will not turn on at all. Is there a reset...
Those plastic screws on the sides are for the brushes for the motor. If you took them out, they need to be re-inserted in the same side they came out of and the curve in the end of the brush has to match the shaft. If you take them back out and look at them there will be a half circle appearance to the ends. Make sure that you put it back in so that the they look like this ( ) in the mixer.
Jan 19, 2011 | KitchenAid Microwave Ovens
Hi my shop rider will not go forward it just juders on the spot the batterys are fully charged but this makes no diffrence
Hi. Sounds like worn motor brushes, or a stuck brush in the motor. Unscrew the brush caps and check that the brushes can move freely. Sometimes it helps to give the brushes a very light filing with a fine file.
When you do up the caps again, be careful as they can crack if done up to tight, but they need to be firm.
Good luck. Neil.
Jul 01, 2010 | Shoprider Front Wicker Scooter Basket
Remove siemens washing machine motor
You probably need to lever the motor back, as it is probably held in place on the motor mounts.
Dec 09, 2009 | Siemens WXLS143 Front Load Washer
My wiper linkage has siezed i have removed the linkage and motor and found that the driver side spindle end is completely siezed and icant move it,the passenger side spindle end moves/seems fine also the...
it might be the motor has siezed. disconnect the linkage from the motor and turn wipers on if works then linkage at fault, if not then motor needs replacing.
Jun 03, 2008 | 2005 Ford Mustang
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Sep 28, 2007 | Vacuums
Health & Beauty Logo
93 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
