Question about Kenmore 54501 Dehumidifier
My dehumidifier runs but lets out warm air. Is there anyway I can repair myself ? What could be the problem? Help,,, Thanks
  • 110 Answers
The dehumidifier is supposed to be releasing warm air. In order for the built-in refrigerator to lower the coolant's temperature, heat must be removed from it. Thus, that removed heat flows out of the unit. If it's a problem, I would suggest having a fan nearby, or perhaps you could put the dehumidifier in a cooler part of the house. (In case you're curious, try looking for any vents near your refrigerator or freezer, and you'll see what I mean.)
Posted on Aug 04, 2010
Cold air is coming out, instead of hot air. how can i fix problem thanks john
if you want hot air the you need a humidifier, it puts warm moist air into the room. used to put moisture in the air if your running a wood stove
Mar 04, 2011 | Kenmore 54701 Dehumidifier
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Tip
Dehumidifier Problems and Dehumidifier Troubleshooting
If you have a dehumidifier that is not working correctly you have many things that could be causing it not to work. Here I will give some of the common reasons why it could be giving you problems.
  1. The coils in the back are frosting up.
The dehumidifier works by drawing the room air over a very cold coil. The trick is to keep the coil as cold as possible to make it pull water out of the air by making it condensate on the cold coil. If this coil becomes too cold, then the water freezes on the coil. The freezing can happen if the air temperature in the room is too cool and does not keep the coil warm enough. Raising the humidifier up off of the floor onto a table can help. The air temperature is often a bit warm the higher up you get. Make sure that the filters are clean if your unit has one. Restricted air flow will make the problem worse. Providing more heat to the room will help also. Most units will not work in a room with temperatures below 68 degrees F.
  1. There is no air moving over the coils.
This can happen if the fan motor becomes stuck or burns out. If it becomes stuck you can sometimes get it running by working a lubricant into the bearings. WD-40 first, and then a good motor oil. If the motor burns out it will need to be replaced.
  1. The indicator light is on and the unit will not run.
This shows you that the bucket is full and needs to be dumped. If your unit is working correctly and the air is very damp you may only run a few hours before the bucket becomes full. This also can happen if the bucket is not seated in it’s spot correctly. There is a little switch that will not let the unit run if the bucket is not place exactly right.
  1. There is no water being produced.
This can happen if the air is very dry and no water can condensate from the air. Check the coils to see if they are cold to the touch, actually they should be very cold, like almost freezing. If not then the refrigeration system of the dehumidifier has gone bad. To repair that you will need a person certified to work on refrigerant systems with specialized equipment. In many cases the costs to repair the refrigeration systems will more than the cost to replace the whole unit.
This should give you a brief overview of the problems that you can have with a dehumidifier and some of the things that you can do to help get things working.
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
on Jan 13, 2010 | Dehumidifiers
Hi I have a Danby DDR3008EE dehumifier that is putting water on floor There is ice inside where the filter is. What should we do besides turn off and let melt?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Good luck.
Aug 14, 2010 | Danby DDR3008EE Dehumidifier
My maytag dehumidifier doesn't dry the air
It's a refrigerant leak. (very common with virtually all dehumidifiers) If it's out of warranty, it's time to buy a new one. (cost prohibitive to repair)
Jun 19, 2010 | Maytag M7DH45B2A Dehumidifier
Air conditioners remove the moisture from the air, and so does a dehumidifier. Does running a dehumidifier make the air conditioner run less? Does running the small dehumidifier save energy in that the...
a dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, but you are correct, when you run an air conditioner it acts like a dehumidifier and dries the air. as far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air use a dehumidifier if you want cool dry air run the AC but not both.
Unit runs but is not operating properly.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 05, 2010 | Whirlpool AD75U Dehumidifier
Unit runs but doesn't pull humidity out of room, filter clean
Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
Jul 18, 2009 | Dehumidifiers
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose.
You need an AC outlet of a central AC in your basement, or a window unit if there are windows.
Warm air at discharge is normal.
Sep 04, 2017 | LG LD40E Dehumidifier
Warm air from side vents..
If your dehumidifier is one that runs at colder temps so it does not ice up, it will have a heater in it to prevent this. That is the warm air you are feeling.
Sep 06, 2008 | Kenmore 53701 Dehumidifier
Kenmore 54501 Dehumidifier Logo
148 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
