Question about HP Color Laserjet 3550 Printer
Jam in front door. I have taken everything apart that I can discern from the helps on line. Can find no paper in the machine. Still have the same message. Jam in Front door.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 03, 2010
My officejet 6110 All-In-One Inkjet Printer says" Open Door clear Carriage Jam, and press Enter" There isn't a jam, and I have opened the door about 20 times now, and have taken off the back...
Hey
often there is a tiny piece of paper stuck somewhere along the path the paper travels, you could try loading a thick piece of photo paper or similar and press the OK button a few times so it feeds the page through the machine.
If that doesn't help it could be a sensor problem, or there might be a foreign object that doesn't belong to the printer inside somewhere, possibly a paper clip or similar.
Unplug the machine and see if you can rotate the gears - or the bars inside the printer and see if something comes out.
If that doesn't help, and you are outside of warranty, you would have to start taking the printer apart to find the problem in the paper path or the stuck switch or sensor thats triggering the paper jam.
theres alot of small parts I don't really recommend it unless you have previous experience.
Nov 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The paper in the printer is lined up and everything should be working however I need to print things for work and it tells me that it is either jammed or that I need to load/ reload the paper. I can't...
I have found over the years that printers really don't lie. If it says there is a paper jam there usually is. I have completely taken apart a large laserjet printer to find a very tiny piece of paper causing the problem. Also if you run sticky labels through printers they have a tendency to leave residue or even part of a label behind which will cause the printer to tell you there is a jam. Check your printer very carefully, use some canned air to blow it out. You may need a printer repair person to come out and take it apart to look for possible stuck paper.
Jul 03, 2010 | Canon Pixma iP2600 Photo InkJet Printer
J01 error, but no paper jam; can't re-set
Remove the toner cartridge.
There should be 2 switch actuators sticking up from the base.
It sounds like one of these actuators has been knocked loose. Try to clip the actuator back on to the sensor.
This is a TOUGH job, you may need a sercive tech to look at it.
Oct 13, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam
you dont you might have a dirty or bad paper sensor there is also a chance the paper might be in the fusing area (where its hot) if u use a flashlight and look in that area you might see the paper at that point it needs to be taken apart
Aug 28, 2009 | Canon LC-3175 Laser Fax
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
Document jam
There is a sensor in the document feeder that most likely is stuck on the frame or the spring fell off and is not resetting. Have you taken a minela folder and run it through the feeder to be sure there is not a small fragmant of paper on the sensors? If you havent try that, or a piece of paper folded in half twice and keep sliding it though the feeder.
You would have to take the feeder apart to get the sensor set, That is best accomplished by taking the back cover off, then the left side cover, ( looking from the front) and disconnecting the feedder connectors, then removing it from the scanner.
Apr 07, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
PAPER BLOCKING
HI there I take it that you have a paper jam open the back door and check that there isn't any paper wrapped around the fuser roller you will be able to see it. If there is then push the little green levers down and try to remove paper from the cartridge side open front cover and remove cartridge if you can see the tail end of the paper pull slowly towards you. once removed close rear door and instll toner and start printing again. If you cannot remove paper from fuser then machine will have to be taken apart the remove paper. Also have you noticed any gray plastic film that has come out with the prints if so then the fuser film is broken and that will need a new fuser unit installed.
If the printer simply doesn't pickup the paper then remove the toner cartridge and using a soft cloth wipe clean the little gray rubber tyre that sits in the middle of the machine then test.
Hope this helps you as I didn't have a lot to go on but
Thanks J
Jan 11, 2008 | HP LaserJet 1300n Printer
Paper jam error
Check rear door for paper fragments check paper jam sensors ussally one front middle and rear make sure they arn't stuck, model make?
Oct 16, 2007 | Office Equipment & Supplies
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
