Question about Eclipse CD3422 CD Player
Brand/eclipse model/cd3432 problem/help 7A300160 is code displayed on screen
Radio worked, battery replaced, radio light up but does not work?
assuming it displays the message "sec"; eclipse models use a securty cd to generate an new temporary security code and let you unlock it if you have that cd it ok but if not you have to get it or get the whole module serviced at your local eclipse dealer...
Apr 25, 2016 | Mercedes-Benz S-Class Cars & Trucks
Power light blinks 5 times. It only displays half of the screen
Hi Mark,
the fault sounds like a t-con board fault, your 5 blink error code means little without the Brand and Model all manufacturer fault codes are different, post your TV Model and Brand for more specific help :o)
Feb 14, 2016 | Televison & Video
Hi I have a Panasonic flat screen tv model TH-37PW5 and have lost the remote, I have a universal remote model RM-E86 but have lost the codes!! Please help. Thanks
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 18, 2016 | Panasonic Televison & Video
Won't load menu and stays on Eclipse screen. Drivers will not load and none are available to download from website. How can I retrieve my music and folders off of it? Please help! Thanks!
I'm afraid your Eclipse died. There is no way to download anything, no way to listen anything, you can't even reformat it. Grt another brand, never buy Eclipse again!
Apr 20, 2015 | Eclipse Fit Clip 4GB* MP3 Player
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
Display mode is flashing
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
Nov 16, 2008 | 2002 Mitsubishi Eclipse
Error codes
unplug radio to run antenna now radio screen display's SEC help then numbers come up at the bottom of SEC . This is for a eclipse3000
Oct 02, 2008 | Eclipse CD3422 CD Player
ECLIPSE 5443 DISPLAY DONT WORK
Hi Rozz,
That is the LCD screen and the backlight has evidently burned out. See if you can find a broken Eclipse of the same model on Ebay and replace your LCD screen.
Mar 21, 2008 | Eclipse 5443
Eclipse CD3422 CD Player Logo
116 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
