Question about Samsung SlimFit TX-S3082WH 30" TV
Blurry Picture Picture is blurring on the left and right sides when being turned on. It subsides after 20 minutes but not completely...
  • Anonymous Sep 23, 2008
    I have the same problem, but the blurriness does not seem to subside.
I had this problem as well. I checked out a bunch of sites like this to find an answer, but everyone had a different solution. My girlfriend however saw that one post said something about removing their surround sound speakers from next to the TV. I insisted that this would not work, but she made me take the sub woofer that was about 10 inches under the TV in the entertainment center. To my surprise within 30 minutes it cleared up and had been fine since.Hope this helps some of you, and saves some hassle and money.
Posted on Aug 12, 2008
  • DominoJr Aug 14, 2008
    Well, the problem has resurfaced already.When i noticed it again i
    thought back to the day i took the speakers away and remembered that we
    had tried another solution prior to that. I had read somewhere else
    that it could possibly be some circuit board that wasn't
    getting enough power so we plugged it directly into the wall socket
    rather than the surge protection 10 way that nearly everything in the
    entertainment center is plugged into. Since the problem came back i
    figure it wasn't the speakers at all rather than the fact that it
    wasn't getting enough juice due to all the other things plugged into
    the 10 way drawing power from the same socket. I plugged the TV
    directly into the wall socket today and more fuzzy picture,
    well it took a minute or two. If the problem reoccurs ill try to find
    another solution and post it. Hope this helps those who have no luck
    with the speaker solution.
  • Samsung Master
  • 1,689 Answers
This is normaly due to the focus bias volts being out of spec, and slowly drifting in to specs. This type of fault is usualy in the high voltage multiplier section that supplies the focus voltage, or in the focus circuit on the the CRT circuit board.
There is also a possiblity that the CRT is going weak, and it is taking some time for its emission to come up.
The TV service tech can do some tests to determine whre the fault actualy is.
Depending on the age, manufacture, and model of the set, would determine the price and availability for parts. If the CRT is the fault, then the set would not be worth to service.
Jerry G.
Posted on Apr 25, 2008
Picture comes out blurry and there appears a hand that appears to be shaking in the top left hand corner of the picture screen
Hand shake means shutter speed is too low to avoid blurred picture(due to low light)
Either increase lighting or
Use flash and turn it on or use higher ISO setting or
Use lowest aperture number.
Last when there is nothing moving in the frame you can use tripod at any P.A.S settings in any lighting
Jun 27, 2010 | Kodak EasyShare V1003 Digital Camera
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Blurry picture
Make sure the lens is clean
Some webcams have a focus ring around the lens you can rotate to sharpen the image - like a telescope.
Others rely on software and you set the focal length for the best picture.
You can try the Philips website for support
Jan 19, 2010 | Philips SPC 600NC Webcam
First two letters on the left are blurry. The
Look inside behind where the carriage is, the plastic strip behind the carriage probably has an ink or grease spot right where you see the blurred letters. Wipe that strip carefully with a Q-tip moist with alcohol, and the blurs should go away...
Dec 13, 2009 | HP PSC 1210 All-In-One InkJet Printer
LCD screen is extremely blurred
It is probably not the LCD itself, but an element that is protecting the LCD is bent out of shape.
Jan 16, 2009 | Vivitar ViviCam 5386 Digital Camera
E have a Nikon Coolpix
I went to the menu and selected restore factory defaults. This seemed to fix the problem. I have since added the date to dislay on the photo and the camera is still OK- no more blurry shots.
Sep 19, 2008 | Nikon Cameras
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba 65h82 picture trouble
Its most likly the Hi voltage/focus block assy. Or there are bad capacitors in the sweep power supply. You should call toshiba and get the number of an authorized Toshiba repair shop.
Oct 08, 2006 | Toshiba 65H82 65" Rear Projection...
Samsung SlimFit  TX-S3082WH 30" TV Logo
253 people viewed this question
Jerry Greenberg
Jerry Greenberg
