Question about Frigidaire Dryers
Hello, I currently own a Frigidaire Affinity FAQG7073KWO gas dryer for several months. Recently when I try to dry my clothes, the display panel does not display how many minutes left and instead displays two slashes that "circle" around the panel. And sometimes the cycle ends earlier than the designated time. I appreciate your feedback. Thank you..
  • 35 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Posted on Dec 09, 2007
rickzilla
  • 706 Answers
SOURCE: Gas dryer not completely drying clothes
Hello br4noles,
based on your description, you may have one of several problems but the prime suspect would be a restrictive exhaust system. Check and make sure you don't have a blockage in your vent system all the way from the dryer to the exit point. When cycling, you should have a fairly robust air flow at the exit outside. If you don't, then you may have a blockage in your vent, something restricting the blower from operating at 100% or lastly a poor flame from your gas system. Air movement is the key thou so I would focus on that since you didn't state that the dryer wasn't heating up.
Regards,
Rick
Posted on Nov 25, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Jahn27
  • 1554 Answers
SOURCE: I have a Frigidaire Affinity Clothes dryer
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Posted on Mar 07, 2011
I have a Frigidaire Affinity FAQG7073KWO gas dryer. When I put clothes in dryer and turn it on, it runs for about 2 to 3 seconds then says PAU. I checked Vents and all hooked up.
Possible duct is clogged up some ..Typical of the circuit board. Sensing back flow air not flowing freely .. It is a multiple problem situation.. From a bad sensor in the exhaust to motor power not correct.. . try to disconnect dryer hose and run it with out for a few minutes.. But because of it beeing gas. Be cautious about monoxide poisoning.. Just a test run would be best..
Nov 06, 2016 | Frigidaire Dryers
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
63 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
